Hi everyone,
I need some help please. My Beovision 4 was moved to another location and by mistake the Data cable( USB to RS232) was damaged. I wonder if someone could help me with the connections into the RS232.
I have 4 cable wires and I do not have any ideea where it goes into the RS232.
Any help will be highly appreciated!
A Very Warm Welcome to Beoworld..
I think the drawing below should help you repair your cable
Regards Keith....
Basically it is a DB 9 null modem cable.
See HERE
Ralf
Thank you for your help.
My cable has 4 wires. The diagram shows actually that only 3 cable are used. The +5V wire is not used at all?
thanks in advance for your help!
Finally, I managed to remove the front screen and PowerON/OFF manually the screen as the Serial cable is not working at all!.
Now I have another problem: the image is zoomed at max ( I see only the top left of the image) and there is not any specs about Zoom in the manual.
Any ideea what IO should to to concerning the Zoom?
thanks in advance for help!
