Beocenter 2200 tape deck problem.
This post has 11 Replies | 1 Follower
riscabill
Posts 7
riscabill Posted: Fri, Mar 22 2013 5:20 PM
I have just installed a new set of belts for the tape player. It starts to play fine, but after fast forward or fast rewind, when it starts to play again the leading cog, i.e the right hand one, keeps stopping and the tape spills out a bit before the whole cassette player stops.
Is this a known issue or have I done something wrong?
thanks in advance.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Fri, Mar 22 2013 5:33 PM
Check the square belt below decks.
It should run only on one side of the motor pulley.
If fitted so that it passes on both sides, it doesn't actually touch the motor pulley and won't be driven.
riscabill
Posts 7
Thanks for the reply,
I've checked the belts but I had installed them correctly. The issue remains the same - once the tape is stopped, I need to tap/press the tape back down before pressing play again. If I don't, the action of the heads engaging pushes the tape off-centre enough that the right hand (leading) cog won't turn and the machine cuts out.
Any ideas?
riscabill
Posts 7
Any ideas?
Dillen
Posts 13,191
Dillen replied on Sun, Apr 7 2013 10:05 PM
The lubrication related to the movement of the tapehead bridge has dried.
There are three or four points.
Clean and relube. Use a little silicone grease (of the non-hardening type obviously).
riscabill
Posts 7
Firstly, thanks for the prompt response. The concept is simple to comprehend; the application less so. Some further questions:
Do I need to dismantle before the lube?
Where exactly do I need to apply it? "Tape head bridge" means little to me, so I was wondering if you had any diagrams with the points marked?
Is silicone spray lubricant suitable? I am finding it difficult to obtain silicone grease in the UK.
Sorry for my non-technical understanding, but I just want my beloved music centre to function as it should!
And thanks yet again.
Bill
Søren Mexico
Mexico City
Posts 6,411
Tape head bridge is the metal piece that moves the tapeheads back and forth, silicone grease here, do not use the spray silicone it will contaminate belts, rubber wheels and tapeheads, and do not have the same lube function as the grease.
riscabill
Posts 7
riscabill replied on Sat, Apr 13 2013 7:16 PM
Okay, I took the unit apart and applied some silicon grease in the places where it clearly needed some. This hasn't fixed the problem... I'll upload a video now, so that you can see the problem a little clearer!
riscabill
Posts 7
riscabill replied on Sun, Apr 14 2013 8:47 PM
Here's a video I made, hopefully makes it a little clearer: http://www.youtube.com/watch?v=hi0ifi7BcRk
Dillen
Posts 13,191
Dillen replied on Mon, Apr 15 2013 6:35 AM
To me, it looks like the pressure roller cannot get into the tape cassette. Pushing the cassette upwards instead
as if it hits the upper edge of the cassette.
Is that correct ?
Something bent or broken ?
riscabill
Posts 7
riscabill replied on Tue, Apr 16 2013 10:34 AM
That doesn't seem to be the trouble. However, there seem to be two stabilising pieces that hold the tape, just either side of the main play head. This looks to be what is pushing the tape, I think. I've attached another video for you to look at: http://youtu.be/anKaU0m9US4
Another interesting thing is what happened when fast forwarding yesterday... it was "jittery". Any ideas, based on what you can see here? http://youtu.be/VcAVoKQ476s
Thanks again everyone!
Dillen
Posts 13,191
Dillen replied on Tue, Apr 16 2013 3:58 PM
The two stabilizers are supposed to go in OVER the cassette and hold it down.
Bend them upwards slightly so they will be allowed to do exactly this.
They must have been inadvertently bent down when you worked on the deck.
Page 1 of 1 (12 items) | RSS
