THis Morning when I turned on the tv a banner told me to retune as there were new services I have completed this task but now all theBBC channel have been removed can anyone help with this thanks in anticipation
I have a feeling the best person to help with this would be an aerial fitter. I assume that since he retune, which possibly was a result of them moving some channels around your aerial and cabling now isn't providing the BBC frequencies to the TV.
i don't understand the technicalities but we had exactly the same. The guy went into the loft for 20 minutes and all was well again.
I would try deleting all the channels and re-tuning. If the signal on other (non-BBC) stations is fine then it is unlikely to be your aerial/cabling because the terrestrial stations will all come from the same transmitter and BBC will be at least as strong a signal as the others. You should be able to check the specific frequencies and reception for your area on a site like this: http://www.digitaluk.co.uk/help_and_advice
