Beovision 7 DVB-T
Nic67
Posts 2
Nic67 Posted: Fri, Mar 29 2013 9:23 AM
THis Morning when I turned on the tv a banner told me to retune as there were new services I have completed this task but now all theBBC channel have been removed can anyone help with this thanks in anticipation
rednik
Posts 182
rednik replied on Fri, Mar 29 2013 9:28 AM
I have a feeling the best person to help with this would be an aerial fitter.  I assume that since he retune, which possibly was a result of them moving some channels around your aerial and cabling now isn't providing the BBC frequencies to the TV.
i don't understand the technicalities but we had exactly the same.  The guy went into the loft for 20 minutes and all was well again.
Guy
Warwickshire
Posts 2,590
Guy replied on Fri, Mar 29 2013 1:08 PM
I would try deleting all the channels and re-tuning.  If the signal on other (non-BBC) stations is fine then it is unlikely to be your aerial/cabling because the terrestrial stations will all come from the same transmitter and BBC will be at least as strong a signal as the others.  You should be able to check the specific frequencies and reception for your area on a site like this: http://www.digitaluk.co.uk/help_and_advice
Page 1 of 1 (3 items) | RSS
