Review BV11 by Techradar - 4.5 out of 5!
This post has 4 Replies | 2 Followers
BeoHut
Posts 482
BeoHut Posted: Thu, Apr 4 2013 8:34 AM
Techradar did a review of the BV11-40.
Here is the link: http://www.techradar.com/reviews/audio-visual/televisions/plasma-and-lcd-tvs/b-o-beovision-11-1141993/review
With all the critics to (new) B&O products, B&O did a great job with introducing this video and audiosystem. Enjoy your reading and be proud that it's still a B&O worth product!
Aussie Michael
Melbourne, AU
Posts 3,730
Thanks for posting. A very interesting review.
To the BV11 owners out there do you concur? Have any of you had any issues?
Cheers
Michael
BeoHut
Posts 482
BeoHut replied on Thu, Apr 4 2013 11:57 AM
Well, I have read in another topic that our member moxxey was talking about dust and fingerprints behind the glass of his BV11. I hope for him it has been removed by the dealer?!
Further I have seen in the flash-topic many new BV11 setups and they look very pleased with it. Not only with the picture and the looks, but also with the amazing sound and other utilities. Still it is waiting for more smart-apps. But therfore you can also use the apps from the AppleTv or BR-player. Even with a MacMini connected to the BV11 will give you a lot of possibilities. I have a BV10 and have no experience with a BV11.
moxxey
South West, UK
Posts 5,359
moxxey replied on Thu, Apr 4 2013 8:19 PM
Beofan53:
No. Based on experience, taking off the glass will/can only make things worse, especially if you have a carpet.
I'm happy with my BV11. The only disappointment is.....the lack of an orange fret!
rxcohen
New York
Posts 201
rxcohen replied on Fri, Apr 5 2013 3:13 AM
The review was spot on, except that i think the Beo4 is great. The picture issues are there, but over time you get use to it. There is also a small defect in that there are some indentations to the seal between the screen and the frame, which may be a reason why there may be dust build up in some TVs. This is an issue with the 55in, which is the size that I have. It may not be there with other sizes. The sound is superb.
One thing is that during the installation B&O could not get the AppleTV to fit into the TV. I think one needs a very thin HDMI cable with a small cable head. The back panels also don't seem to stay quite flush. Very very minor cosmetic issue that is invisible.
Overall it provides a great cinematic experience.
BV11-55, BS9000, BL1, BL19, Transmitter 1, Beo4, Beocom 6000, BeoTalk1 200, Sennheiser HD600, McIntosh MHA100
Page 1 of 1 (5 items) | RSS
