Beofan53:Well, I have read in another topic that our member moxxey was talking about dust and fingerprints behind the glass of his BV11. I hope for him it has been removed by the dealer?!
No. Based on experience, taking off the glass will/can only make things worse, especially if you have a carpet.
I'm happy with my BV11. The only disappointment is.....the lack of an orange fret!
The review was spot on, except that i think the Beo4 is great. The picture issues are there, but over time you get use to it. There is also a small defect in that there are some indentations to the seal between the screen and the frame, which may be a reason why there may be dust build up in some TVs. This is an issue with the 55in, which is the size that I have. It may not be there with other sizes. The sound is superb.
One thing is that during the installation B&O could not get the AppleTV to fit into the TV. I think one needs a very thin HDMI cable with a small cable head. The back panels also don't seem to stay quite flush. Very very minor cosmetic issue that is invisible.
Overall it provides a great cinematic experience.
BV11-55, BS9000, BL1, BL19, Transmitter 1, Beo4, Beocom 6000, BeoTalk1 200, Sennheiser HD600, McIntosh MHA100
