My pc died. What should I do?
This post has 4 Replies | 2 Followers
jans
Belgium
Posts 394
jans Posted: Sat, Apr 6 2013 9:56 AM
I have a Beo5 which I program with the version 6 config tool. I used an old 32 bit windows pc specially for programming the beo5. Unfortunately my PC died last week.
All my other pc's at home are Apple MacBooks and iMac.
What are the recommendations from the forum? Can I run the config tool on a 64-bit IMac? Or should I buy a new windows pc? The Beo5 requires a 32bit, but most pc's nowadays are 64 bit. Any recommendations which PC would be right for me?
Regards
Jan
Peter
Earsdon
Posts 11,991
Peter replied on Sat, Apr 6 2013 9:59 AM
Buy Parallels or use Bootcamp and run Windows on the mac . I did this to program my Beo5 in the past.
Peter
Orava
Finland
Posts 991
Orava replied on Sat, Apr 6 2013 10:49 AM
Virtual machine with windows?
Keith Saunders
Hampshire, United Kingdom
Posts 5,495
jans:
Whilst most PC's today use 64 bit architecture, you can still install a 32 bit Windows operating system on 64 bit hardware.
The issue of 64 bit vs 32 bit as far as the Beo5 is concerned relates to the USB driver which means you will need to connect it to a Windows PC for reliable operation.
Regards Keith....
jans
Belgium
Posts 394
jans replied on Wed, Apr 10 2013 6:32 PM
Thanks all for your inputs. I 'll keep you posted on my next steps.
Jan
Page 1 of 1 (5 items) | RSS
DigiCert Secured Site Seal
