My Beocenter 8500 is having following problem:
* When the 8500 is turned on, the tape recorder start 'snurring' and I will have to either turn it all off, and start up again.
This is a strange problem, and I don't know what to do about it.
Any good ideas?
BRgds Erik
I suggest that the belt/s need changing.
You can buy replacement belts from member "dillen"
Regards Graham
