Beocenter 8500 - Tape recorder 'snurring' problem?!
This post has 1 Reply | 0 Followers
skovboel
Posts 1
skovboel Posted: Sun, Apr 14 2013 2:35 PM
My Beocenter 8500 is having following problem:
* When the 8500 is turned on, the tape recorder start 'snurring' and I will have to either turn it all off, and start up again.
This is a strange problem, and I don't know what to do about it.
Any good ideas?
BRgds Erik
joeyboygolf
Ely, Cambridgeshire, UK
Posts 4,188
I suggest that the belt/s need changing.
You can buy replacement belts from member "dillen"
Regards Graham
Page 1 of 1 (2 items) | RSS
