BG CD 3500 Datalink
This post has 9 Replies | 0 Followers
BenSA
Durban, South Africa
Posts 1,404
BenSA Posted: Sun, Apr 14 2013 6:28 PM
Hi
Seem to having a lot of problems lately!!
Now the datalink on my CD3500 isn't working....the wires came off the plug. I looked on Beotech for the wiring diagram and resoldered the wires put the CD won't switch on when I select CD on the Beomaster. I;'ve connected the wired as follows:
Pin 7 - White
Pin 5 - Blue
Pin 3 - Pink
Pin 2 - Shield
Anyone have any clues? It can't be because I've connected a Beolink converter to link the Beosystem and my Beovision. Both on Opt 1
Ben
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sun, Apr 14 2013 6:37 PM
Haven't you got pins 5 and 7 mixed up ?
Pin 7 is datalink and that's usually a blue or yellow wire.
Pins 3 and 5 are left and right audio signals and they are usually white and red.
BenSA
Posts 1,404
BenSA replied on Sun, Apr 14 2013 7:17 PM
Hi Martin
I just changed the wires around as you said and still won't come on when CD is selected on the Beomaster. Otherwise I'm getting sound etc.......
If its gone faulty I'm going to lose my mind!!!
Dillen
Posts 13,191
Dillen replied on Sun, Apr 14 2013 9:03 PM
Could it be that the datalink should be at pin 6 ?
I must admit, I don't remember.
Which Beomaster do you connect it to ?
BenSA
Posts 1,404
BenSA replied on Mon, Apr 15 2013 8:20 AM
Its connected to a Beomaster 3500. There is no pin in 6, there never has been. Only been a pin is 7!??
BenSA
Posts 1,404
BenSA replied on Thu, Apr 18 2013 10:20 AM
Anyone have the correct colours for wiring to each pin? As far as I can see from diagrams, white is datalink?
Is it possible to damage the datalink?
Ben
joeyboygolf
Ely, Cambridgeshire, UK
Posts 4,188
Red is right signal Pin5
White is left signal Pin3
Blue is datalink Pin 6 or 7  ( or both so they can be used with RIAA or non RIAA systems)
Regards Graham
BenSA
Posts 1,404
BenSA replied on Thu, Apr 18 2013 10:55 AM
Thanks Graham
I'll check them again when I get home after work. I guess if the datalink doesn't work after this then I've run into a problem.
Ben
Dillen
Posts 13,191
Dillen replied on Thu, Apr 18 2013 12:25 PM
There are almost always some protective diodes associated with the datalink signal.
I suggest you check them.
BenSA
Posts 1,404
BenSA replied on Fri, Apr 19 2013 8:20 AM
Its the beogram with is the problem....maybe the cable is faulty? I tried the Beogram on my Beomaster 6500 and it did the same thing,
Even though I have a multimeter I would know how to test a diode....is there anyway I can test the cable?
Thanks again!
Ben
Page 1 of 1 (10 items) | RSS
