Beovision 11
This post has 52 Replies | 3 Followers
Chris Townsend
Qatar
Posts 3,531
A interesting article, which ironically makes me a little more content with my imminent 11 arrivalLets have a Party !!!
The future sure is interesting and as i'm about to shell out yet more cash, not quite mainstream.
fredpert
Posts 103
fredpert replied on Sun, Nov 9 2014 11:03 AM
Hi Beofans!
I am new here and wanted to get your opinion as I plan to buy a Beovision 11-46 in the next couple of weeks... its price went down in France and it will also soon be delivered with the Beo Remote One which makes the deal even better!
I was looking for the best compromise between picture quality and great sound as I want to have a simple setup to watch TV/movies but also listen to my music (stored on a Mac)
Do you think the Beovision 11 would be enough to answer this need and provide a crisp and deep music experience? For those who connected a Sub to the TV, is it improving a lot the sound picture? Is there any noticable defaults on this screen before I sign? ;)
Thanks a lot for all your feedbacks and wish I become a B&O user soon.
FREDPERT
BeoVision 11-46 full black - BeoRemote One
Hiort
Sweden
Posts 2,895
Hiort replied on Sun, Nov 9 2014 4:03 PM
fredpert:
Hi Beofans!
Hi Fredpert!
Welcome to the forum.
There are some excellent reviews of the Beovision 11 on this site. Use the Search function and you will find it.
I personally swapped my BV10-40 for a BV11-46. It's an excellent TV with an amazing picture and sound. I use it with a Beolab 11 and that gives that extra depth to the sound when watching movies.
If I where you I would add a Playmaker to easily play the music you have on your Mac. You then just use AirPlay from your Mac to the playmaker, and play the sound from your BV11.
If you have an iDevice you can use Apple remote app to easily access the music.
fredpert
Posts 103
Hi Hiort,
Thanks for your reply.
I tryed but couldn't find any reviews on BV 11, can you eventually copy and paste the path to get there?
I was thinking about adding a BL11 or BL19. Is this extra depth noticable also when you listen to music?
Regarding the Playmaker, I guess it would work the same if I use an Apple TV, isn't it?
I am just not sure about the finishings. I quite like the Silver frame with the white fret but heard the fret is fragile and after a while, especially on the white, you see the speakers through the fret. What about the black color then, does it solve the problem? What is your color combination?
FREDPERT
BeoGreg
South of France
Posts 1,417
BeoGreg replied on Sun, Nov 9 2014 6:09 PM
fredpert:
For movies sound is just perfect for me without a sub (bass are incredible) for music tv alone it's not enough for my taste.
I still much prefer my good ol' beolab 8000 (with bs 9000) over the bv11 alone.
I think you should get bl 17 or 20 for music.
Millemissen
Flensborg, Denmark
Posts 14,680
fredpert:
Try this thread.
Maybe you can get some information and inspiration there - especially from the posts that KMA made.
http://archivedforum2.beoworld.org/forums/t/3372.aspx?PageIndex=1
fredpert
Posts 103
fredpert replied on Mon, Nov 10 2014 12:19 PM
Thanks Beogreg,
I would love to get extra BL18 but I can't afford it if I buy the BV11... The good thing with this TV is that you can expand the system later anyway
FREDPERT
fredpert
Posts 103
fredpert replied on Mon, Nov 10 2014 12:27 PM
Thank you for the link Millemissen.
Very good review from KMA indeed!
However I see that the panel on more recent models suffers from backlight troubles... Do you have any infos concerning this issue?
FREDPERT
rxcohen
New York
Posts 201
rxcohen replied on Mon, Nov 10 2014 7:21 PM
I now have had my BV 11-55 for almost 2 years. It is a great TV and the sound is very impressive. There is a backlit problem (with my TV at least), in that light images against black will show some ghosting, as well as some minor LED bleeding. So it is great, but not a perfect TV. At first it bothered but over time you get use to it and it does not bother you as much. BR videos look absolutely fantastic.
On the sound front there is a significant difference in the sound between the BV11-46 and 11-55. The 11-55 can standalone without additional speakers for music and movies. However the sound does improve with additional speakers. I have BL-1s, and looking at acquiring a BL-19 for that extra power at the low end, frankly mostly for music rather than film.
Aesthetically i prefer the BV11 over the Avant. But if the Avant eliminated the backlighting light issue of the BV11, I would probably go for it.
Hope this helps
BV11-55, BS9000, BL1, BL19, Transmitter 1, Beo4, Beocom 6000, BeoTalk1 200, Sennheiser HD600, McIntosh MHA100
Hiort
Sweden
Posts 2,895
Hiort replied on Tue, Nov 11 2014 1:53 PM
fredpert:
Could see that someone linked to the post I was thinking of. You can also read on this page. Its a review at FlatpanelsHD.
fredpert:
Seldom play music through the BV11, but when I do the BL11 certainly add extra depth.
fredpert:
Correct. The DAC in Playmaker is however considered much better.
fredpert:
The white may collect dust as you mention. My dealer says B&O will replace the fret if that would happen. I have the black fret with the black frame. Look stylish in my mind. I bought it used form my dealer, so I had no choice regarding the frame, but I'm happy with the looks.
Amazone
Netherlands
Posts 187
Amazone replied on Tue, Nov 11 2014 2:29 PM
The DAC in the playmaker might be better than the DAC in the Airport Express, but that's not the same as in the AppleTV. AppleTV is connected via HDMI and cooperates perfectly with the BV11 (PUC). It also fits completely within the housing. Much better airplay without any dropouts. I see no reason to prefer a playmaker above the AppleTV, especially when connected to a BeoVision. The AppleTV is a much better choice here.
BeoVision 11-55, BeoLab 8000, BeoRemote One BT, AppleTV 4, 2x BeoPlay A2, BeoPlay A1
olvisab
Posts 1,391
olvisab replied on Tue, Nov 11 2014 2:53 PM
Amazone:
BeoVision 11-55, BeoLab 8000, Beo6, AppleTV, BeoPlay A2
One big reason is that the appletv is absolutely not dlna compatible. I personnally stream everything with dlna. If the apple tv was compatible I would buy one for sure.
4 beolab 5,  beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2,  2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
rxcohen
New York
Posts 201
rxcohen replied on Tue, Nov 11 2014 3:58 PM
In terms of finish i chose he black frame. I think the silver looks more interesting if you have accompanying silver speakers. However the benefit of the black finish is that the frame seems to disappear when the TV is on, and it looks like one piece of borderless glass or image.
Page 2 of 2 (53 items) < Previous 1 2 | RSS
