Set top box controller
Jonathan
Melbourne, Australia
Posts 1,811
Jonathan Posted: Tue, Apr 23 2013 8:49 AM
Can anyone tell me whether the software for the STB-C is on the module itself?
I have an Avant that died, but the STB-C is the latest update. I want to put that module into another Avant..... Will it work?????
x:________________________
RaMaBo
near Munich
Posts 626
RaMaBo replied on Tue, Apr 23 2013 9:07 AM
Hi Jonathan,
the chip with the wanted (latest update) codes is in the STB-Controller Module so it should work if both Aants are not to different. There are just two cables connectedto the STB-Controller. One is connected to the Avant and the other one is for the connection of the small PCB containg the 3,5 mm phone plug for the IR Blaster.
RaMaBo
Ralph-Marcus
Keith Saunders
Hampshire, United Kingdom
Posts 5,495
As stated, you can transfer the STB controller completely or just the chip
Regards Keith....
Jonathan
Posts 1,811
Jonathan replied on Thu, Apr 25 2013 6:49 AM
Perfect! It was really easy!!
Thanks so much to both of you for the help Yes - thumbs up
Page 1 of 1 (4 items) | RSS
