x:________________________
Hi Jonathan,
the chip with the wanted (latest update) codes is in the STB-Controller Module so it should work if both Aants are not to different. There are just two cables connectedto the STB-Controller. One is connected to the Avant and the other one is for the connection of the small PCB containg the 3,5 mm phone plug for the IR Blaster.
RaMaBo
Ralph-Marcus
As stated, you can transfer the STB controller completely or just the chip
Regards Keith....
Perfect! It was really easy!!
Thanks so much to both of you for the help
