Beolab 50, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9 3rd Gen, BeoPlay H6, EarSet 3i, BeoVision Eclipse Gen 2 55", BeoPlay V1-40, BeoCom 6000 and so much else :)
Only cables left.Headset jack and short, hard and fragile cables. Cables resoldered to the headset jack.Assembled, with lots of super glue to keep it there. Mission accomplished!Test OK!
Are you sure Michael? Text seems to be wrong, "anslutet"?? :-)
Good job!
Brengen & Ophalen
Leslie: Are you sure Michael? Text seems to be wrong, "anslutet"?? :-) Good job!
Yes, Swedish might sound a bit wrong but I can assure you that it is understandable Swedish :D
Thanks!
Seems that superglue is a B&O's best friend.
After double-sided tape..
