BC6000 headset jack loose & fix
Michael
Sweden
Posts 2,578
Michael Posted: Wed, Apr 24 2013 9:52 AM
Hi, a friend was playing with my phone a few weeks ago and suddenly broke the headset jack on the top of the phone.
Actually it got loose but useable. However when I tried to remove the cable it tore out the entire jack and I was left with a hole and four small cables.
Has this happened to anyone else? I think the connector is a very strange one and you apply quite a lot of stress on it because of its stupid design (Ericsson originally I think).
I took the phone apart (fun of course, at least when I finally got it apart!) and took everything out and realized that the cables where extremely fragile and stiff.
Had to take apart my other BC6000 to see how the wires to the connector should be.
Managed to solder the superthin and short cables and assembled everything again - with a lot of superglue inside the small plastic case that the connector goes into to minimize the risk of it happening again.
Success! It works.
I'm putting up pictures later in case anyone might have use for them for the same issue :).
Michael
Sweden
Posts 2,578
Michael replied on Mon, May 6 2013 8:46 PM
Only cables left.
Headset jack and short, hard and fragile cables.
Cables resoldered to the headset jack.
Assembled, with lots of super glue to keep it there.
Mission accomplished!
Test OK! Smile
Leslie
the Netherlands City
Posts 5,423
Silver Member
Leslie replied on Mon, May 6 2013 9:02 PM
Are you sure Michael? Text seems to be wrong, "anslutet"?? :-)
Good job!
Brengen & Ophalen
Michael
Sweden
Posts 2,578
Michael replied on Mon, May 6 2013 9:23 PM
Leslie:
Good job!
Yes, Swedish might sound a bit wrong but I can assure you that it is understandable Swedish :D
Thanks!
Playdrv4me
USA
Posts 477
Seems that superglue is a B&O's best friend.
MediaBobNY
Greenwich Village, NYC
Posts 1,106
After double-sided tape..
Page 1 of 1 (6 items) | RSS
