Hi, does anyone know how I can connect my Sonos ZP90 to my BeoSystem 3???
Currently my Sonos ZP90 is connected to a beosound 3000 via Aux in using RCA's. This works fine, and is available via master link A.MEM and A.TAPE in my link rooms.
However, I want to change things around and use the BeoSystem 3 so I can utlise the Digital signal from the Sonos ZP90.
I have tried a number of ways to connect, but it would appear the BeoSystem only listed to the audio (RCA/Dig) when there is a video signal present. I have tried connecting via the various AV, both using Scart converters, RCA only, Digital only, combination of both, but it only listens to the audio when I put a video signal in from a video source. i.e. I put a static camera into the videon source, it plays the Sonos, so the signal is there.
I have tried this using the picture mute, and again it will not listen to audio only.
I'm not an engineer, so treat me gently, there must be a solution.....anyone up for it????
Many thanks
Thanks Martin, this is very helpful. A couple of questions;
1. How do I upgrade the software on my beosystem 3 to get this software.
2. Re ml distribution, could I use both analog and digital input to AV6 to get digital off the main room using bs3 and analog via ml rooms?
Many thanks.
