Yes, you can take out the record signals from the TAPE socket at the rear of the Beocenter 7000and feed it to any line level input of any amplifier.
You need a 5 pin DIN (Audio Aux) lead, which should be plugged in to either TV/AUX, CD, TAPE1 or TAPE2 of the BM7000.
Selection using the Beo4 depends upon what input you chose, but I suggest that you go for the TV/AUX input and add 'A.AUX' as a virtual button to the LIST function of the remote. Alternatively, use TAPE2 and add TAPE2 to the Beo4 LIST.
EDIT: You probably already have your TV attached to the TV/AUX, hence use the TAPE2 input. If your Beo4 is quite new, you may have to add N.RADIO rather than TAPE2 in order to select this input - the IR code is the same.
EDIT2: The 'plastic cork' is probably the LINE IN/OUT 'jumper' (left hand socket as you view from the rear) and should not be removed - otherwise all sound output will cease!
It should work fine because a 5 pin DIN (audio aux) socket/cable provides both an input and output. This in this example it will be the output from the BC (of whatever is playing at the time - be it radio, tape or phono) and input to the BM7000.
The BM7000 LINE IN/OUT is there for a graphic equalizer - it enables you to connect one in circuit with the built in amplifier. I doubt that it is used very often!
