Avant screen disable.
This post has 6 Replies | 0 Followers
jimbobjim
Posts 23
jimbobjim Posted: Tue, Apr 30 2013 3:19 PM
I've looked all over or an answer but can't seem to find what I'm looking for.
I have a PS3 hooked up to my Avant 28" VHS (8133), and would like to know if there is a way to disable the screen, whilst listening to music.
I often listen to music all day... so this would be really useful for saving power, and prolonging the TV's lifespan.
Thanks.
James.
Guy
Warwickshire
Posts 2,590
Guy replied on Tue, Apr 30 2013 3:24 PM
Welcome to the forum!
Not sure if it will work for you, but did you try the AV button as explained here: http://archivedarchivedforum2.beoworld.org/forums/p/20396/152173.aspx#152173
jimbobjim
Posts 23
jimbobjim replied on Tue, Apr 30 2013 4:13 PM
Thanks Guy, but that didn't work. Can't even add the "AV" function, as it isn't in the list on my remote.
However, there is an AV button on the remote... but pressing that seems to do nothing. I even pressed it at the same time as I pressed V-AUX, and still nothing happend.
Am I missing something?
Millemissen
Flensborg, Denmark
Posts 14,680
Got it setup in V-option 2?
Greetings MM
Guy
Warwickshire
Posts 2,590
Guy replied on Tue, Apr 30 2013 6:23 PM
jimbobjim:
You should press the buttons sequentially, AV then V.AUX or whatever.
As suggested by Millemissen, you may well need to check the 'option' settings.  Turn the system off, press the RED button and LIST together, then press LIST until OPTION appears in the display, then press GO.  Press LIST until V.OPT appears and then press 2.  This puts the TV in Video Option 2 and should change the way that it responds to remote commands.
pf85
Posts 284
pf85 replied on Wed, May 1 2013 9:15 AM
You may check if <<P.Mute>> on Beo4 works on the Avant. That shuts down the screen.
Guy
Warwickshire
Posts 2,590
Guy replied on Wed, May 1 2013 9:39 PM
pf85:
Sadly it doesn't!
Page 1 of 1 (7 items) | RSS
