I reshimmed the inside of the voice coil, then repaired the spider by simply painting The Wet Look along the side of the spider. I ended up applying 3 coats, letting the woofer set 20 minutes after each coat.
And then I reglued the dust cap. I will let this woofer set overnight, then solder the braided wire back on the leads in the morning when I start working on the crossovers.
Speaking of the crossovers: I ordered the parts for those from Michigan on Wednesday and got them today. Still don't have the glue kit I ordered from Florida. What's that about?
The last thing I did tonight was attach another rubber surround to the basket. By tomorrow night I should have two woofers completely done.
Rich:Still don't have the glue kit I ordered from Florida. What's that about?
How about its chemical composition? This stuff always seemed like rebadged ... white glue!!!
ɓʋɾɑɳɫɘɮ: Rich:Still don't have the glue kit I ordered from Florida. What's that about? How about its chemical composition? This stuff always seemed like rebadged ... white glue!!!
The kit I'm waiting for has four different adhesives, but you're right. Whether it's "The Wet Look," "Mod Podge," or somebody's speaker refoaming glue, it always looks and acts like PVA, water-down PVA, or extra thick PVA!
Status update on the woofers: two fully repaired and ready to go; one at the rubber surround reattachment phase; and one patiently waiting his turn with the shims and clamps.
These two got their leads resoldered this morning, plus I did the touch up paint all over.
I desoldered the crossovers this morning as well. This shot shows one crossover with the capacitors and the resistors removed, and the second crossover as removed from the speaker.
One approach to refurbing these crossovers would be to just swap out new electrolytic capacitors for the old electrolytic capacitors. You could just snip the leads of the old and put in the new.
But that's not how I roll.
You can see on both boards I've circled two of the mounting holes. This is two-way reminder: (1) obviously this tells you which holes to use when screwing the board back into the speaker; and (2) it serves to remind me NOT TO COVER THE DAMN THING!!!! Yes, I've done that very thing in the past (Beovox P30s).
Also, you can see I've left a yellow and a red wire on the desoldered board. These are jumpers I'll need if I recreate the same mounting pattern as the original. It remains to be seen if I will - have to try a "dry fit" first.
Just for kicks I checked the resistance of a few of the old resistors. A 1 ohm measured 1.2 ohms, a 6.8 measured 6.8, an 8.2 measured 8.2, and 150 ohm measured 147.9. In the spirit of "Pictures Or It Didn't Happen," see below.
Getting interesting, steely eyed approach and technique, cant wait to "hear"
One crossover done. New Solen polypropylene capacitors, new wire. Reused inductors (as always) and resistors. I had purchased new Lynx resistors but they didn't work on the existing board. Since the resistors all tested well within spec, no reason not to reuse them.
The P45, like the M70, has a removable back. The back (and baffle) is a thermoset plastic. It connects to the rest of the cabinet with 8 screws. I'll need to replace the gasket that sits on the back of the cabinet.
Here's a shot with the crossover reinstalled into an otherwise empty cabinet. Note the phase link's subchamber in the middle of the box.
I hooked up one set of drivers and gave them a listen without reinstalling the damping material and the back, just to make sure the woofers work.
I'm more than a little pleased to report that both formerly stuck woofers are now working!
Time for a break for some dinner out with the family.
Glue kit from Simply Speakers update: left Miami on Friday, but still no delivery.
USPS Priority Mail, 100 miles, 1 week for delivery and counting.
Meanwhile, I don't need any of the glue any more.
Rich: Glue kit from Simply Speakers update: left Miami on Friday, but still no delivery. USPS Priority Mail, 100 miles, 1 week for delivery and counting. Meanwhile, I don't need any of the glue any more.
USPS may have employed some Mexican workers, I shipped from McAllen to DK with USPS arrived day 3, If you let ship to my son over there, and he ship it back to you, I think it will go faster
Rich: I hooked up one set of drivers and gave them a listen without reinstalling the damping material and the back, just to make sure the woofers work. I'm more than a little pleased to report that both formerly stuck woofers are now working! Time for a break for some dinner out with the family.
Great! Congrtulations! I glad if my project has inspired someone.
Orava: I glad if my project has inspired someone.
You were correct in your thread that the work is not difficult. You just need plenty of patience.
Brief update: the two woofers I used to demo need their leads repaired, but the other two are ready to go. One crossover is complete, and both cabinets have been gone over with paint thinner to remove the splashes of paint on them. I intend to fully reassemble one speaker this evening and see how it sounds.
Rich: You were correct in your thread that the work is not difficult. You just need plenty of patience.
Oh yes, not rocket science
Awesome. If you got the drivers working correctly, these speakers should be well worth the effort.
--mika
They all work fine. Quite keen to have a listen but there's still more "grunt work" to do.
A bit of catch up. This is an example of the lousy condition of the rosewood cabinet.
After applying lots of a "green" paint thinner substitute with a rag and lots of rubbing. The cabinet finish should restore fairly well, but there are some gouges that have taken bits of the veneer completely off. I'll have to fill those gouges with some filler that has some stain in it. But that's down the road.
The first speaker has been completely reassembled except for the fret. All new wiring, new capacitors, new gasket for the back, and new terminal cup. Original damping material was reused. All drivers confirmed working after playing test tones (in mono) from the Stereophile Test CD 3. Played some Beach Boys after that (to the delight of my youngest daughter), then some Stones.
Very Good Job Rich, congrats. And the frets, which fabric ?
Well done sir! Impressive.
//Bo.A long list...
Søren Mexico: And the frets, which fabric ?
Something special is planned. Stay tuned.
And the second speaker is repaired and reassembled. I am extremely pleased to report all drivers are working. I can confirm what Lassi earlier reported: P45 woofers can be repaired!
I also wanted to give an update on the glue kit I ordered from Simply Speakers.
On Monday I emailed Simply Speakers and told them the package was in MIami after a week. A nice person named Sean replied that was strange, but it isn't unknown that tracking info from the USPS can be wrong. The package would likely show up in a day or two.
On Wednesday there were no further tracking updates from USPS, and I emailed Sean with that info. Sean promptly sent me another kit via first class mail (instead of priority mail as the original).
I'm sure most of you already know the outcome to this story. BOTH packages arrived today. Priority mail takes 9 or 10 days to travel less than 100 miles, whereas first class mail is next day.
Rich: Søren Mexico: And the frets, which fabric ? Something special is planned. Stay tuned.
The "something special" will have to wait until the next speaker project. Or maybe I'll redo the P30s with the "something special." They still have their original fabric.
And so comes to close another successful and fun project. In the last week I gave the stripped cabinets two coats of teak oil and I put new fabric on the frets. Here's the result.
The P45s have replaced my P30s in the garage Beosystem 2400. Subjectively they play about twice as loud as the P30s. Which is a good thing.
They still sound fantastic. Definitely worth the rebuild effort. Another highly recommended loudspeaker from Bang & Olufsen.
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, 2014 Audi S5 with B&O sound, and ambio
After about 2 months, these P45s still sound great, and the woofers still rock! Earlier today I was playing "Big Bottom" from Spinal Tap and admiring the "big bottom" of these speakers which once had stuck woofers.
A toast: to saving loudspeakers from the skip!
Rich: After about 2 months, these P45s still sound great, and the woofers still rock! Earlier today I was playing "Big Bottom" from Spinal Tap and admiring the "big bottom" of these speakers which once had stuck woofers. A toast: to saving loudspeakers from the skip!
A toast to you and your excellent job, I have mine playing with my BM 4400 and love them, and yes direct on the wall, big bottom.
cool, for sure deserves a toast.
did not see this tread until today, and must say it is inspiring!
cheers
How did I miss this? Brilliant thread.
I've butchered a fair few stuck Beolit speakers in the past with dire results. If there's ever a next time.....
If you think nobody cares, try missing a couple of payments.
Great story Rich.
Thanks, guys. The Beosystem 2400 with P45s in the garage still gets a few hours of play each week. There's always something to do in the garage, right?
I think the P30s are probably better suited to the space, though, but I can't be bothered with swapping them back in right now.
I can't believe it's been over a year and a half since I messed with a pair of speakers. I have really gott to get out of this cassette rabbit hole I've fallen into.
Thanks a lot for sharing this amazing project with us.
I do hope You will enjoy these speakers for years of good music.
Best regards
René
What a great project! Fascinating to read.
I've recently purchased some P45's and they need a bit of love to get them back to their full glory. I would love it if some of you could provide some advice. I've posted the details here:
https://archivedforum2.beoworld.org/forums/t/34546.aspx
Thanks!
