Beolit 12: can I turn on with Beo4?
Veermer
Murcia, Spain
Posts 49
Veermer Posted: Sun, May 12 2013 6:29 PM
Hello to all the big experts of this forum. I have a question regarding Beolit 12. I usually use a Beo4 (stick versión) to control some basic function like turn off, volumen and change track, with the CD button. But I can not turn on the Beolit with it. Is it possible to do it? And it is possible to turn on the AirPlay too?
Thanks!
Beovision 10-46, Beocenter 1, Beo 4, Beocom 4, Beolit 12, Beosound 4, Beosound Essence, Beolab 6000
Roger
Norway
Posts 417
Roger replied on Sun, May 12 2013 7:33 PM
You turn on the BeoLit 12 by pressing an Audio function on the Beo4 (e.g. CD). You skip to the next track in the same fashion as for a CD.
You can not turn on the AirPlay.
Roger
hfat
Vienna, Austria
Posts 663
I once put together a list of all sources available from all BeoPlay products. You can even connect to your network with the V.MEM command.
Standby puts the device into standby. An IS source commands wakes it up again.
hfat
Veermer
Murcia, Spain
Posts 49
Veermer replied on Tue, May 14 2013 6:21 AM
Thanks Roger. But I am trying to do it and it doesn't works. Any sugestion?
Veermer
Murcia, Spain
Posts 49
Veermer replied on Tue, May 14 2013 6:26 AM
hfat thanks for your answer, but what "IS source" means? Sorry for my ignorance....
Page 1 of 1 (5 items) | RSS
