Hello to all the big experts of this forum. I have a question regarding Beolit 12. I usually use a Beo4 (stick versión) to control some basic function like turn off, volumen and change track, with the CD button. But I can not turn on the Beolit with it. Is it possible to do it? And it is possible to turn on the AirPlay too?
Thanks!
Beovision 10-46, Beocenter 1, Beo 4, Beocom 4, Beolit 12, Beosound 4, Beosound Essence, Beolab 6000
You turn on the BeoLit 12 by pressing an Audio function on the Beo4 (e.g. CD). You skip to the next track in the same fashion as for a CD.
You can not turn on the AirPlay.
Roger
I once put together a list of all sources available from all BeoPlay products. You can even connect to your network with the V.MEM command.
Standby puts the device into standby. An IS source commands wakes it up again.
hfat
Thanks Roger. But I am trying to do it and it doesn't works. Any sugestion?
hfat thanks for your answer, but what "IS source" means? Sorry for my ignorance....
