Beolink passive turns itself on?
This post has 1 Reply | 0 Followers
petebest1471
Posts 6
petebest1471 Posted: Sun, May 12 2013 10:56 PM
I have a beolink passive set which powers two outdoor speakers. I had a whole host of trouble with a dodgy eye but got that replaced with a brand new one and all was good. However... I had the eye outside, under cover but with no weatherproof case, but I found that on occasion, the outside speakers would turn themselves on (onto the radio). There was no timer set, the beolink and the beocenter 2 had the correct settings. I can find no reason for it.
I have now invested in an outdoor case just in case condensation was getting in to the eye and it has been fine for the last week. But, low and behold for no apparent reason the system just started turning itself on and off at random today. The only thing different between today and any other day was that there was rain...)
Surely I haven't been unlucky enough to get get hold of two dodgy eyes can I? Has anyone else had this happen to them before, if so, what was the answer? I'm really starting to loose faith in this B&O stuff!
Thanks,
Pete
I unplugged the IR eye - problem over
BeoHut
Posts 482
BeoHut replied on Mon, May 13 2013 6:12 PM
First check your cables. Probably the IR-eye is triggered by something/someone?
What about the connections inside the IR-eye? Try to open it and have a look. Are the cablesconnections still good?
Or, someone is fooling you and tries to make you mad ;-)
Page 1 of 1 (2 items) | RSS
