In addition to my existing Beosound Ouverture I got a Beosound 5 which I want to integrate in my coniguration: BV 7-40 MKV, BL8000, BL11, BL6000 attached to powerlink of the BV7. I have set the BV7 to Option 2, the Ouverture to Option 0. The Besound 5 is set as Audio Master (AM) and also Option 0. That leads to the effect, that pressing "Radio" on the BEO4, both the Ouverture and the Beosound 5 start playing radio. I tried more options like Ouverture on option 6, but there is no sound.
Is this a basic problem i.e. 2 Beosounds cannot work in the same configuration or is there a fix or workaround to the problem? Please help, as I have no more ideas of how to configure this.
Regards, rpaul
Reinhard Paul
BV11, BL8000, BL6000, BL11, Ouverture, BS5/BM5, Beocom 2
Hello, I have the same problem. BV7, BS9000 (audiomaster) BS5 (Slave). One can have only one Audimaster. I had to take the BS9000 for it, otherwise radio and CD correctly does not work. Moreover, I needed this for the reproduction timer in the BV7. Otherwise the spring is not indicated. Disadvantage with this configuration - Spotify is not available. Have also BV7 on Opt.2, BS9000 on 0 and BS5 Slave
BeoVision 7-40 HD-Modul, BeoViision 11-40, BeoVision 8 32" white + Floor Stand, 2x Apple TV 4 mit Kodi, DVD2, HDR2, BeoSound 9000 MKIII White Edition, 2x BeoSound Moment + Floor Stand, 2x BeoSound Stage, BeoSound Core, BeoSound 35 brass, BeoSound 1 MKII + Floor Stand, 2x BeoSound 3, BeoSound 6, BeoSound 3200, BeoSound Essence , BeoPlay A9 Nordic Sky twilight, BeoPlay A8 MKII white + Floor Stand, BeoPlay A2 grey, 2x BeoPlay A3 white/bright blue, BeoPlay A1, 2x BeoPlay S3 white, Beolit 12 (White Edition), Beogram TX2, BeoLab 5, BeoLab 3, BeoLab 7-4, BeoLab 8000 MKII, Beolab 11, 2x BeoLab 3500, 4x LC2, 4x Beo4 - MK1-3, BeoRemonte One BT, 2x BeoRemonte Halo, Audio Terminal, Beolink 1000, BeoLink 7000, 2x EarSet A8, 3x A9 Keyring, EarSet 2, Form2, BeoPlay H6, 3x BeoTime, Beowatch, 2x Lightmanager Pro+ B&o Version, 4x BeoCom5, Beoline2, 3x Speakerphone, BeoTalk 1200, 5x Cabinets, MLGW, BLGW,
You should set Ouverture to A.Opt 4. When you want to play e.g. radio from Beosound Overture you have to press link radio.
hfat
I tried it, but after pressing link/radio nothing happened. The Ouverture does not respond. By just pressing radio, the Beosound 5 repsonds with the selected radio programme and the Ouverture just turns the light on, otherwise keeps silent.
rpaul:I tried it, but after pressing link/radio nothing happened.
Sorry, I just checked. The Ouverture only support a.opt 0,1,2 and 6.
hfat: You should set Ouverture to A.Opt 4. When you want to play e.g. radio from Beosound Overture you have to press link radio. hfat
As far as I remember older Ouvertures just offered "A.OPT 0 / 1 / 2" and newer ones (SW2.1) can be set to "A.OPT 5 / 6" too.
Maybe I'm wrong, I've used "L.OPT 4" on BLB 3500s and "V.OPT 4" on serveral TVs, but I can't remember ever having seen "A.OPT 4" being accepted by any audio product.
Part of the problem might be the old SW level in my ouverture. Nevertheless there should be a workaround to the problem. I`ll try to play around with different roles options in the Beosound 5. One solution - however very crude - solution is to switch off the one Beosound not in use- But that is not very B&O like! There should be a smoother option.
Regards, Reinhard rpaul
rpaul:Part of the problem might be the old SW level in my ouverture.
No - the BeoSond Overture simply has never been updated to be "Netmusic / Netradio" compliant.BTW, SW 2.1. update kit for Ouverture - which won't solve your specific issue (i'ts offering link-room use of an Ouverture as a secondary local system in A.OPT 5 + 6) is not any longer available.
rpaul: One solution - however very crude - solution is to switch off the one Beosound not in use- But that is not very B&O like! There should be a smoother option.
If you don't use cassettes - replace your Ouverture e.g. by a second hand Beosound 3000 ...
I tried to changes roles in the BS5 and it worked, not perfect though because I have to press Radio twice on the Beo4 to get the Ouverture playing radio and I have to switch the Ouverture to standby before going back to TV.
Thanks for the hint Peter, the simple things are sometimes really the best!
Regards from Wiesbaden, Germany
Reinhard
