Beosound 5 and Ouverture in one Config
This post has 9 Replies | 2 Followers
Reinhard Paul
Wiesbaden, Germany
Posts 26
Reinhard Paul Posted: Fri, May 17 2013 5:57 AM
In addition to my  existing Beosound Ouverture I got a Beosound 5 which I want to integrate in my coniguration: BV 7-40 MKV, BL8000, BL11, BL6000 attached to powerlink of  the BV7. I have set the BV7 to Option 2, the Ouverture to Option 0. The Besound 5 is set as Audio Master (AM) and also Option 0. That leads to the effect, that pressing "Radio" on the BEO4, both the Ouverture and the Beosound 5 start playing radio. I tried more options like Ouverture on option 6, but there is no sound.
Is this a basic problem i.e. 2 Beosounds cannot work in the same configuration or is there a fix or workaround to the problem? Please help, as I have no more ideas of how to configure this.
Regards, rpaul
Reinhard Paul
BV11, BL8000, BL6000, BL11, Ouverture, BS5/BM5, Beocom 2
Iceman10245
Berlin - Germany Nova Santa Ponsa-Islas Baleares
Posts 186
Hello, I have the same problem. BV7, BS9000 (audiomaster) BS5 (Slave). One can have only one Audimaster. I had to take the BS9000 for it, otherwise radio and CD correctly does not work. Moreover, I needed this for the reproduction timer in the BV7. Otherwise the spring is not indicated. Disadvantage with this configuration - Spotify is not available. Have also BV7 on Opt.2, BS9000 on 0 and BS5 Slave
BeoVision 7-40 HD-Modul, BeoViision 11-40, BeoVision 8 32" white + Floor Stand, 2x Apple TV 4 mit Kodi, DVD2, HDR2, BeoSound 9000 MKIII White Edition, 2x BeoSound Moment + Floor Stand, 2x BeoSound Stage, BeoSound Core, BeoSound 35 brass,  BeoSound 1 MKII + Floor Stand, 2x BeoSound 3, BeoSound 6, BeoSound 3200, BeoSound Essence ,  BeoPlay A9 Nordic Sky twilight, BeoPlay A8 MKII white + Floor Stand, BeoPlay A2 grey, 2x BeoPlay A3 white/bright blue, BeoPlay A1, 2x BeoPlay S3 white,   Beolit 12 (White Edition), Beogram TX2, BeoLab 5, BeoLab 3, BeoLab 7-4, BeoLab 8000 MKII, Beolab 11, 2x BeoLab 3500, 4x LC2, 4x Beo4 - MK1-3, BeoRemonte One BT, 2x BeoRemonte Halo, Audio Terminal, Beolink 1000, BeoLink 7000, 2x EarSet A8, 3x A9 Keyring, EarSet 2, Form2, BeoPlay H6, 3x BeoTime, Beowatch, 2x Lightmanager Pro+ B&o Version, 4x BeoCom5, Beoline2, 3x Speakerphone, BeoTalk 1200, 5x Cabinets, MLGW, BLGW,
hfat
Vienna, Austria
Posts 663
hfat replied on Fri, May 17 2013 6:42 AM
You should set Ouverture to A.Opt 4. When you want to play e.g. radio from Beosound Overture you have to press link radio.
hfat
Reinhard Paul
Wiesbaden, Germany
Posts 26
I tried it, but after pressing link/radio nothing happened. The Ouverture does not respond. By just pressing radio, the Beosound 5 repsonds with the selected radio programme and the Ouverture just turns the light on, otherwise keeps silent.
Regards, rpaul
Reinhard Paul
petermc
Australia
Posts 128
petermc replied on Fri, May 17 2013 9:53 AM
On the BS5 in the Settings menu and down to Roles is N Music & N Radio set to these options.
Under Roles you can set the BS5 to respond to N Music when pressing CD and N Radio when pressing radio.
Just a thought.
Peter
hfat
Vienna, Austria
Posts 663
hfat replied on Fri, May 17 2013 12:59 PM
rpaul:
Sorry, I just checked. The Ouverture only support a.opt 0,1,2 and 6.
hfat
Vienna
make an educated guess
Posts 1,090
Vienna replied on Fri, May 17 2013 1:03 PM
hfat:
hfat
As far as I remember older Ouvertures just offered "A.OPT 0 / 1 / 2"  and newer ones (SW2.1) can be set to "A.OPT 5 / 6" too.
Maybe I'm wrong, I've used "L.OPT 4" on BLB 3500s and "V.OPT 4" on serveral TVs, but I can't remember ever having seen
"A.OPT 4" being accepted by any audio product.
Reinhard Paul
Wiesbaden, Germany
Posts 26
Part of the problem might be the old SW level in my ouverture. Nevertheless there should be a workaround to the problem. I`ll try to play around with different roles options in the Beosound 5. One solution - however very crude - solution is to switch off the one Beosound not in use- But that is not very B&O like! There should be a smoother option.
Regards, Reinhard rpaul
Reinhard Paul
Vienna
Posts 1,090
Vienna replied on Sat, May 18 2013 3:53 AM
rpaul:
No -  the BeoSond Overture simply has never been updated to be "Netmusic / Netradio" compliant.
BTW, SW 2.1. update kit for Ouverture - which won't solve your specific issue (i'ts offering link-room
use of an Ouverture as a secondary local system in A.OPT 5 + 6) is not any longer available.
rpaul:
If you don't use cassettes - replace your Ouverture e.g. by a second hand Beosound 3000 ...
Reinhard Paul
Wiesbaden, Germany
Posts 26
I tried to changes roles in the BS5 and it worked, not perfect though because I have to press Radio twice on the Beo4 to get the Ouverture playing radio and I have to switch the Ouverture to standby before going back to TV.
Thanks for the hint Peter, the simple things are sometimes really the best!
Regards from Wiesbaden, Germany
Reinhard
Reinhard Paul
Page 1 of 1 (10 items) | RSS
