I was generously gifted a Beovision 6 - 26 (type 9257) tv but the remote and other components were sold. Since I will only use as tv what are my best remote controller options. Will it function with just the remote or do I need other components? Thanks for advise
Hi and welcome to BeoWorld,
what do you mean by "other components"?
Greetings MM
Hi ... I am not familiar with this brand. I may have misspoken on "other components". There was no operating manual so I have had to research online to find out about it. I keep coming across beo this and beo that ... all I know is there is no "on" button. Guess I need basic help.
You need a remote to be able to switch it "on" ... it is actually on, but in standby.
You need to buy from a dealer the Beo4 remote, or look on eBay for a Beo4 or a Beolink 1000 which will do most of the functions.
I am sorry about that ....
BeoNut since '75
Thanks for the information. I am sure I will love it when I am all set up.
