Hello guys!
Do anyone of you have experience with connecting the new Apple TV to a Beovision 6 26"?
What I'm wondering about is of course the connections on the BV6 getting dated...
Thanks in advance!
Andreas
Too long to list....
Not entirely sure. First check if your tv has a DVI input. Then check if its HD-ready. If these two are confirmed you need only use a HDMI-DVI adapter. Then connect Apple TV with HDMI and use optical sound out of Apple tv to line-in in tv problem solved.
Worst case senario is that you may need HD-kit into tv. Check with your local dealer for price.
Alternatively, purchase BeoPlay V-1.
You would need the hd-ready kit, an optional dolby digital decoder for your sound and a seperate ‘optical > coaxial decoder unit’. And the stb-controller is useless for the DVI-input. Picture-wise the BV6 is outdated too...
Your better of with any other brand TV.
I disagree, I use a WDTV live via DVI with analog left and right audio. The picture is a good as it gets, even better than most modern TV's, colour and sound is amazing. (OK the res is dated, but hey it's only 26"...)
Don't give up on the BV6, its a great little TV :)
I forgot to mention, that I now have a BV11-55 (1 week old) with the Beolab 3's (7 years old and 5 house moves in 2 countries!) that used to run with the BV6-26 (now in the bedroom), also a BV6-22 in the guest bedroom, the 1st Bang and Olufsen product that I bought, 10 years ago? WOW, what other brands could stand time so well!
Thanks guys.
I'm unsure wether to get an old BV6, or just get a new bell and whistles TV for the bedroom...
So the optical cable would supply the sound then? Will the Apple TV be sending sound via the optical even if the HDMI is connected? (I'm guessing yes)
bayerische: So the optical cable would supply the sound then? Will the Apple TV be sending sound via the optical even if the HDMI is connected? (I'm guessing yes)
Yes it will. But still you need a 3rd party device to convert the optical signal. 2 options here:
To display content via the DVI there is another issue that can occur: HDCP. Without the the HD-ready kit installed it’s more than likely you will have problems, renting a movie.
I’m just trying to be objective here, but on a forum like this, opinions will always be strongly biased. The only reason I would buy an old BV6 would be because of the sound and if the TV is connected to a masterlinked system. If connecting an Apple TV has higher priorities, I would look further. And like I said earlier, the DVI-input cannot be controlled with the stb-controller, so you will still need 2 remotes.
Chris Townsend:There are plenty of 8-26's popping up and I have been impressed with ours. The 6 is a better looking TV there's no doubt, but even a single hdmi socket makes a big difference.
The BV8 is a good machine, but I can't get over the design.
DoubleU: bayerische: So the optical cable would supply the sound then? Will the Apple TV be sending sound via the optical even if the HDMI is connected? (I'm guessing yes) Yes it will. But still you need a 3rd party device to convert the optical signal. 2 options here: a box that converts to analog L/R so you won’t need the optional DSM. a box that converts to coaxial if the DSM is installed. To display content via the DVI there is another issue that can occur: HDCP. Without the the HD-ready kit installed it’s more than likely you will have problems, renting a movie. I’m just trying to be objective here, but on a forum like this, opinions will always be strongly biased. The only reason I would buy an old BV6 would be because of the sound and if the TV is connected to a masterlinked system. If connecting an Apple TV has higher priorities, I would look further. And like I said earlier, the DVI-input cannot be controlled with the stb-controller, so you will still need 2 remotes.
I actually have one of those converters... However... Not being able to use the STB controller using DVI is about to kill this idea for me. That was the biggest reason for the B&O TV...
A HD-ready BV6 will basically work "out-of-the-box" with an apple tv then?
I really appreciate the help.
Hi, If the 6-26 has the HD Ready scaler then the DVI socket is controllable wit the STB controller in the sockets menu together with the HD source DVI or Component inputs! Tos to Coax signal converters are available on ebay for a tenner!
This is what I have in my kitchen
Regards Dougie c
I have once tried to connect my BV 6-26 (which I have sold for a new Loewe TV afterwards) with my Apple TV. The Beovision had a DVI input but no HD kit (scaler) installed. I could not use the Apple TV since the picture was flickering every 5 - 10 seconds in all screen resolutions that Apple TV supports.
So maybe you should try to get your hands on a later model 6-26 that is HD ready (mine was a 2006 model).
Kind regards,
Mike
Hi, You could always look for a Beocenter 6-26 which is HD Ready from the factory and has better software
Regards DC
What about the BV6 - 22"?
Would that work?
After getting some new furniture for the bedroom, I noticed that the space where I'd like to put the TV is about 100cm, and I don't want a too big TV in the bedroom, it will be too dominating.
StUrrock:Ever tried a hd fury ?
Nope, but googled it.
I'd be so much simpler off by just buying a third party TV, as pretty much the only connection I need is Apple TV.
But the design... I can't get over the plastic thingies... The new big Samsung TV's with the thin bezel looks great, why can't they make a nice small TV?
This is the space I need the TV for. The drawers chest is about 100cm, so putting a big TV on it is not an option... I think it will ruin the look of the drawer.
".....Samsung TV's with the thin bezel looks great".
Even the sound is thin!
Grrr! MM
Buy a suitable small (white)16/9 display with HDMI, connect the audio via DAC to an Active Link (PC-input), and a couple of small BL's.....
....and AirPlay the content to the ATV (set to 'always on').
This way you can reach the audio sources in the main room as well.
(http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?slg=en&scy=gb&ctn=248C3LHSW/00)
Greetings Millemissen
bayerische:This is the space I need the TV for. The drawers chest is about 100cm, so putting a big TV on it is not an option... I think it will ruin the look of the drawer.
What a perfect spot for a white MX4000!
--mika
Millemissen: Buy a suitable small (white)16/9 display with HDMI, connect the audio via DAC to an Active Link (PC-input), and a couple of small BL's..... ....and AirPlay the content to the ATV (set to 'always on'). This way you can reach the audio sources in the main room as well. (http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?slg=en&scy=gb&ctn=248C3LHSW/00) Greetings Millemissen
I've been thinking of that, but would like the B&O design.
V1-32 in white - and your sorrows are gone!
Greetings MM
Millemissen: V1-32 in white - and your sorrows are gone! Greetings MM
Too industrial.
tournedos: bayerische:This is the space I need the TV for. The drawers chest is about 100cm, so putting a big TV on it is not an option... I think it will ruin the look of the drawer. What a perfect spot for a white MX4000!
Too big.
Yours is pretty spotless though!
Seems that you really are determinated for the BV6-26
Millemissen: Seems that you really are determinated for the BV6-26 Greetings MM
It's a great looking TV. Too bad they didn't update and continue making it.
http://www.ebay.co.uk/itm/Bang-Olufsen-Beovision-6-26-HD-HDMI-connections-/230998987456?pt=UK_AudioTVElectronics_Video_Televisions&hash=item35c89cd2c0
theres always this hd bv6 on eBay
