Apple TV to Beovision 6 26"
This post has 29 Replies | 1 Follower
bayerische
Ekenäs, Finland
Posts 4,770
bayerische Posted: Sun, May 26 2013 9:00 AM
Hello guys!
Do anyone of you have experience with connecting the new Apple TV to a Beovision 6 26"?
What I'm wondering about is of course the connections on the BV6 getting dated...
Thanks in advance!
Andreas
Too long to list....
scottyltd
Posts 19
scottyltd replied on Sun, May 26 2013 11:21 AM
Not entirely sure. First check if your tv has a DVI input. Then check if its HD-ready. If these two are confirmed you need only use a HDMI-DVI adapter. Then connect Apple TV with HDMI and use optical sound out of Apple tv to line-in in tv problem solved.
Worst case senario is that you may need HD-kit into tv. Check with your local dealer for price.
Alternatively, purchase BeoPlay V-1.
DoubleU
Posts 562
DoubleU replied on Sun, May 26 2013 12:31 PM
You would need the hd-ready kit, an optional dolby digital decoder for your sound and a seperate ‘optical > coaxial decoder unit’. And the stb-controller is useless for the DVI-input. Picture-wise the BV6 is outdated too...
Your better of with any other brand TV.
splud
Posts 24
splud replied on Sun, May 26 2013 1:21 PM
I disagree, I use a WDTV live via DVI with analog left and right audio. The picture is a good as it gets, even better than most modern TV's, colour and sound is amazing. (OK the res is dated, but hey it's only 26"...)
Don't give up on the BV6, its a great little TV :)
splud
Posts 24
splud replied on Sun, May 26 2013 1:36 PM
I forgot to mention, that I now have a BV11-55 (1 week old) with the Beolab 3's (7 years old and 5 house moves in 2 countries!) that used to run with the BV6-26 (now in the bedroom), also a BV6-22 in the guest bedroom, the 1st Bang and Olufsen product that I bought, 10 years ago?  WOW, what other brands could stand time so well!
bayerische
Ekenäs, Finland
Posts 4,770
bayerische replied on Sun, May 26 2013 11:37 PM
Thanks guys.
I'm unsure wether to get an old BV6, or just get a new bell and whistles TV for the bedroom...
So the optical cable would supply the sound then? Will the Apple TV be sending sound via the optical even if the HDMI is connected? (I'm guessing yes)
Chris Townsend
Qatar
Posts 3,531
There are plenty of 8-26's popping up and I have been impressed with ours. The 6 is a better looking TV there's no doubt, but even a single hdmi socket makes a big difference.
DoubleU
Posts 562
DoubleU replied on Mon, May 27 2013 7:09 AM
bayerische:
Yes it will. But still you need a 3rd party device to convert the optical signal. 2 options here:
  • a box that converts to analog L/R so you won’t need the optional DSM.
  • a box that converts to coaxial if the DSM is installed.
To display content via the DVI there is another issue that can occur: HDCP. Without the the HD-ready kit installed it’s more than likely you will have problems, renting a movie.
I’m just trying to be objective here, but on a forum like this, opinions will always be strongly biased. The only reason I would buy an old BV6 would be because of the sound and if the TV is connected to a masterlinked system. If connecting an Apple TV has higher priorities, I would look further. And like I said earlier, the DVI-input cannot be controlled with the stb-controller, so you will still need 2 remotes.
bayerische
Ekenäs, Finland
Posts 4,770
Chris Townsend:
The BV8 is a good machine, but I can't get over the design. Sad
Chris Townsend
Qatar
Posts 3,531
Once I got one home on its stand I soon got over it. It's never going to be a 6 though let's face it. There are a view hdmi 6-26 to be had but at ridiculous prices.
bayerische
Ekenäs, Finland
Posts 4,770
DoubleU:
bayerische:
I actually have one of those converters... However... Not being able to use the STB controller using DVI is about to kill this idea for me. That was the biggest reason for the B&O TV...
A HD-ready BV6 will basically work "out-of-the-box" with an apple tv then?
I really appreciate the help.
Douglas
Edinburgh & Essen, Germany
Posts 58
Hi, If the 6-26 has the HD Ready scaler then the DVI socket is controllable wit the STB controller in the sockets menu together with the HD source DVI or Component inputs! Tos to Coax signal converters are available on ebay for a tenner!
This is what I have in my kitchen
Regards Dougie c
Mike
Stuttgart, GERMANY
Posts 4
Mike replied on Tue, May 28 2013 8:11 PM
I have once tried to connect my BV 6-26 (which I have sold for a new Loewe TV afterwards) with my Apple TV. The Beovision had a DVI input but no HD kit (scaler) installed. I could not use the Apple TV since the picture was flickering every 5 - 10 seconds in all screen resolutions that Apple TV supports.
So maybe you should try to get your hands on a later model 6-26 that is HD ready (mine was a 2006 model).
Kind regards,
Mike
Douglas
Posts 58
Hi, You could always look for a Beocenter 6-26 which is HD Ready from the factory and has better software
Regards DC
bayerische
Ekenäs, Finland
Posts 4,770
What about the BV6 - 22"?
Would that work?
After getting some new furniture for the bedroom, I noticed that the space where I'd like to put the TV is about 100cm, and I don't want a too big TV in the bedroom, it will be too dominating.
StUrrock
Posts 995
StUrrock replied on Sat, Jun 15 2013 6:06 PM
Ever tried a hd fury ?
bayerische
Ekenäs, Finland
Posts 4,770
StUrrock:
Nope, but googled it.
I'd be so much simpler off by just buying a third party TV, as pretty much the only connection I need is Apple TV.
But the design... I can't get over the plastic thingies... The new big Samsung TV's with the thin bezel looks great, why can't they make a nice small TV? Stick out tongue
This is the space I need the TV for. The drawers chest is about 100cm, so putting a big TV on it is not an option... I think it will ruin the look of the drawer.
Millemissen
Flensborg, Denmark
Posts 14,680
".....Samsung TV's with the thin bezel looks great".
Even the sound is thin!
Grrr! MM
StUrrock
Posts 995
StUrrock replied on Sun, Jun 16 2013 11:40 AM
Is this worth a go, dont know whether it needs a hdmi display connected to it to work?
We use it to connect via hdmi in the main room then send the modulated composite video signal around the good old link system. Brings new life to all the old 'analogue' only BeoVision tvs.
word of caution the HDMI input device can only be set to 720p.
http://www.cypeurope.com/store/store/app/product/CM-388/HDMI-Down-Scaler-with-Bypass-Output
Millemissen
Flensborg, Denmark
Posts 14,680
Buy a suitable small (white)16/9 display with HDMI, connect the audio via DAC to an Active Link (PC-input), and a couple of small BL's.....
....and AirPlay the content to the ATV (set to 'always on').
This way you can reach the audio sources in the main room as well.
(http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?slg=en&scy=gb&ctn=248C3LHSW/00)
Greetings Millemissen
tournedos
Finland
Posts 7,357
tournedos replied on Sun, Jun 16 2013 2:44 PM
bayerische:
What a perfect spot for a white MX4000! Big Smile
--mika
bayerische
Ekenäs, Finland
Posts 4,770
Millemissen:
I've been thinking of that, but would like the B&O design. Wink
Millemissen
Flensborg, Denmark
Posts 14,680
V1-32 Smile in white - and your sorrows are gone!
Greetings MM
bayerische
Ekenäs, Finland
Posts 4,770
bayerische replied on Sun, Jun 16 2013 11:11 PM
Millemissen:
Greetings MM
Too industrial. Big Smile
bayerische
Ekenäs, Finland
Posts 4,770
bayerische replied on Sun, Jun 16 2013 11:12 PM
tournedos:
bayerische:
Too big. Big Smile
bayerische
Ekenäs, Finland
Posts 4,770
tournedos:
bayerische:
Yours is pretty spotless though! Cool
Millemissen
Flensborg, Denmark
Posts 14,680
Seems that you really are determinated for the BV6-26 Stick out tongue
Greetings MM
bayerische
Ekenäs, Finland
Posts 4,770
bayerische replied on Mon, Jun 17 2013 12:36 PM
Millemissen:
Greetings MM
It's a great looking TV. Too bad they didn't update and continue making it.
Chris Townsend
Qatar
Posts 3,531
Or even made a 32 inch version with HDMI sockets. I'd buy one at V1 prices in a flash.
2012martin
Posts 202
http://www.ebay.co.uk/itm/Bang-Olufsen-Beovision-6-26-HD-HDMI-connections-/230998987456?pt=UK_AudioTVElectronics_Video_Televisions&hash=item35c89cd2c0
theres always this hd bv6 on eBay
Page 1 of 1 (30 items) | RSS
