DVB HD software update
david707
Posts 146
david707 Posted: Mon, May 27 2013 4:38 PM
I notice there are new DVB software updates. Do B&O publish a change log for these or are we owners expected to guess what the improvements are?
gysse2004
Hellerup
Posts 192
gysse2004 replied on Mon, May 27 2013 5:24 PM
The 1.9.9.0 is the one for the DVB-HD, and has been for some time
Peter
Beovision eclipse 65, Beolab 50, Beolab 18, Beovision 11, Beolab 3, Beolab 2, BeoVision 10, MLGW, BeoLink converter Nl/Ml, Beosound 5, BLGW
david707
Posts 146
david707 replied on Mon, May 27 2013 8:23 PM
Thanks, But there's no information (on the B&O site) stating the changes made for each revision. I could understand them not publishing this information if it was an engineers job, but the customer is expected to carry this out so needs the information to see if its worth bothering with the download/USB stick etc.
Mine is still running 0.1.8.9. Should I upgrade? If so why? What are the changes? It seems to work OK except for the 4 seconds or so of blank screen when changing channels that is.
gysse2004
Hellerup
Posts 192
gysse2004 replied on Mon, May 27 2013 10:00 PM
Hi David
I can't remember the changes, but I am running 1.9.9.0 on my BS3, and I think it is just as stable if not better.
Peter
gysse2004
Hellerup
Posts 192
gysse2004 replied on Mon, May 27 2013 10:04 PM
Ps: 4 seconds pr. channel change does not sound right. what TV do you have ?
david707
Posts 146
david707 replied on Tue, May 28 2013 10:55 AM
Beovision 8-40  type 9560 build 210. DVB HD (not T2) s/w 0.1.8.9
Channel changes are slow as I said around 4 seconds from command through blank screen to picture reappearing. Source change is slower still approx 5 seconds. For e.g from TV to DTV.
stefan
200 miles from Struer
Posts 2,920
stefan replied on Tue, May 28 2013 11:42 AM
As far as I heard from Struer, the 1.8.9 to 1.9.9 update fixes some bugs for UK television, and you shouldn`t update, if you are using Conax with Canal Digital.
So if you are based in UK, just try the update.
Stefan
david707
Posts 146
david707 replied on Tue, May 28 2013 2:07 PM
That is useful to know thanks Stefan.
Guy
Warwickshire
Posts 2,590
Guy replied on Tue, Dec 21 2021 6:32 PM
stefan:
Stefan
Eight years after this post and I just carried out this update on my 'new' BV10-32.  I am not yet sure what has changed, but thanks Stefan!
Page 1 of 1 (9 items) | RSS
