Hello,
Is it normal to hear a low fan noise on a BV10-46?
BR
alevost
Before I had a major software upgrade the other week, I never heard the fan at all.
Since receiving the latest software upgrade, I can now hear a fan. And it's annoying. It sounds like that flicking noise you get when something gets caught in your bike wheel. Ok, it's much quieter than that, but that's the best comparison I can make.
So, yes, I also hear a low fan noise and, yes, I'd say it's frustrating.
BeoGreg: Never upgrade the software if everything works fine !
Yeah, but the BV10-46 has/had a known fault where the software couldn't be updated at all as it required a new mainboard - massive job and the dealer organised that himself after purchase.
Plus the result was that the sound quality improved dramatically, so can't complain!
moxxey: Plus the result was that the sound quality improved dramatically, so can't complain!
Oh, Oh, good to see that the sound quality improved only by a software upgrade.
The mainboard and the panel (and the remote sensor) also been changed on my tv, what a job indeed.
It's strange that your fans make more noise after the update, have you checked if they are not running too fast whith the new software ?
Gregory
Yes.
Too long to list....
Zwaan:Wat parameters do you have in service menu? In submenu fan adjustment? Fan full speed temp Fan stop speed temp And wat are THE temperature 1 and 2 I have THE problem too. Een i change THE fan stop speed from 48 to 54 THE noise is gone
Zwaan:NOS, i know 48 is default. When i put THE tv out and on, 54 is changed in 48
alevost:Hello, Is it normal to hear a low fan noise on a BV10 - 46 ? BR alevost
