Is it normal to hear a low fan noise on a BV10-46?
This post has 11 Replies | 1 Follower
alevost
Posts 1
alevost Posted: Wed, Mar 28 2012 10:50 AM
Hello,
BR
alevost
moxxey
South West, UK
Posts 5,359
moxxey replied on Wed, Mar 28 2012 12:30 PM
Before I had a major software upgrade the other week, I never heard the fan at all.
Since receiving the latest software upgrade, I can now hear a fan. And it's annoying. It sounds like that flicking noise you get when something gets caught in your bike wheel. Ok, it's much quieter than that, but that's the best comparison I can make.
So, yes, I also hear a low fan noise and, yes, I'd say it's frustrating.
BeoGreg
South of France
Posts 1,417
BeoGreg replied on Wed, Mar 28 2012 1:48 PM
I can hear a very low fan noise on my BV 10-40.
If I watch tv and the sound is on I forget about it.
Nothing disturbing like Moxxey said.
Never upgrade the software if everything works fine !
Gregory
moxxey
South West, UK
Posts 5,359
moxxey replied on Wed, Mar 28 2012 1:59 PM
BeoGreg:
Yeah, but the BV10-46 has/had a known fault where the software couldn't be updated at all as it required a new mainboard - massive job and the dealer organised that himself after purchase.
Plus the result was that the sound quality improved dramatically, so can't complain!
BeoGreg
South of France
Posts 1,417
BeoGreg replied on Wed, Mar 28 2012 2:11 PM
moxxey:
Oh, Oh, good to see that the sound quality improved only by a software upgrade.
The mainboard and the panel (and the remote sensor) also been changed on my tv, what a job indeed.
It's strange that your fans make more noise after the update, have you checked if they are not running too fast whith the new software ?
Gregory
Zwaan
Posts 121
Zwaan replied on Fri, Oct 5 2012 9:15 PM
I have THE bv10-46 sinecure one week. I hear also THE noise off à fan. What speed must have THE fan??
bayerische
Ekenäs, Finland
Posts 4,770
Yes.
Too long to list....
Yendys
Sydney
Posts 312
Yendys replied on Fri, Oct 5 2012 11:43 PM
I have a Mk 1 BV10 40 and only when I place an ear right up to the top/ back panel can I hear a fan, not during general listening
Zwaan
Posts 121
Zwaan replied on Sun, Oct 7 2012 8:49 AM
Wat parameters do you have in service menu? In submenu fan adjustment?
Fan full speed temp
Fan stop speed temp
And wat are THE temperature 1 and 2
I have THE problem too. Een i change THE fan stop speed from 48 to 54 THE noise is gone
Zwaan
Posts 121
Zwaan replied on Sun, Oct 7 2012 7:19 PM
Zwaan:
Fan full speed temp
Fan stop speed temp
NOS, i know 48 is default. When i put THE tv out and on, 54 is changed in 48
Zwaan
Posts 121
Zwaan replied on Mon, Oct 8 2012 6:32 PM
Zwaan:
it isn't true what i said. Its not default, i was forgotten to put GO
Zwaan
Posts 121
Zwaan replied on Mon, Oct 8 2012 6:36 PM
alevost:
Hello,
Is it normal to hear a low fan noise on a BV10 - 46 ?
BR
alevost
after wat time do you hear this??? I hear THE noise off THE fan when THE temperature is 51 Gr. And THE fan has more than 1840 rpm. (adjustment 2x0 go). After 2 hours.
Page 1 of 1 (12 items) | RSS
