Hi all, would a Beogram 5500 work properly with my 5000 system & MCP 5000? Any help would be very much appreciated. Thanks Mike
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, 2014 Audi S5 with B&O sound, and ambio
I'm not sure either, I thought it was something to do with the RIAA and the MCP. I think i'll just buy it and hope for the best. Thanks for your help.
It should work - you aren't controlling the BeoGram directly with the MCP5000, the signals go through your BM5000 via DataLink. I've even used a BeoCord 8004 with my BC2300 without any problems as they use the same type of DataLink as described here.
- Dennis
Thanks Dennis, i've made up my mind to buy it.
Thanks again
Mike
The 5500 will work perfectly with your Beomaster 5000.
Regards Graham
