Beogram 5500 to Beomaster 5000
45625direct
Posts 5
45625direct Posted: Fri, May 31 2013 11:49 AM
Hi all, would a Beogram 5500 work properly with my 5000 system & MCP 5000? Any help would be very much appreciated. Thanks Mike
DMacri
United States
Posts 881
DMacri replied on Fri, May 31 2013 12:13 PM
I'm not positive, but I thought it was only a cosmetic change from the 5005 to the 5500, so it should work just fine.
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, 2014 Audi S5 with B&O sound, and ambio
45625direct
Posts 5
I'm not sure either, I thought it was something to do with the RIAA and the MCP. I think i'll just buy it and hope for the best. Thanks for your help.
Dennis
Denmark
Posts 627
Dennis replied on Fri, May 31 2013 12:56 PM
It should work - you aren't controlling the BeoGram directly with the MCP5000, the signals go through your BM5000 via DataLink.  I've even used a BeoCord 8004 with my BC2300 without any problems as they use the same type of DataLink as described here.
- Dennis Smile
45625direct
Posts 5
Thanks Dennis, i've made up my mind to buy it.
Thanks again
Mike
joeyboygolf
Ely, Cambridgeshire, UK
Posts 4,188
The 5500 will work perfectly with your Beomaster 5000.
Regards Graham
Page 1 of 1 (6 items) | RSS
