I have an ipod connected to the Beosound 1 , which buttons play the ipod please ?
If you have an older Beosound without the start/stop timer function, press << and >> simultaneously. This will put it in Aux mode. If you have a newer one press both < CD > simultaneously.
Thankyou MediaBob
It was too easy , I notice the volume has halved .
Is this normal?
johnrb47: Thankyou MediaBob It was too easy , I notice the volume has halved . Is this normal?
Probably dependent on the volume setting of your iPod - I normally have mine set quite high, just a shade under the maximum and control the volume of the B&O
BeoNut since '75
Thanks so much elephant
All is sweet
