ipod with Beosound 1
johnrb47
Posts 3
johnrb47 Posted: Sat, Jun 1 2013 2:19 AM
I have an ipod connected to the Beosound 1 , which buttons play the ipod please ?
MediaBobNY
Greenwich Village, NYC
Posts 1,106
If you have an older Beosound without the start/stop timer function, press  << and >> simultaneously.  This will put it in Aux mode.  If you have a newer one press both  <  CD  >  simultaneously.
johnrb47
Posts 3
Thankyou MediaBob
It was too easy , I notice the volume has halved .
Is this normal?
elephant
AU
Posts 8,219
johnrb47:
Thankyou MediaBob
Is this normal?
Probably dependent on the volume setting of your iPod - I normally have mine set quite high, just a shade under the maximum and control the volume of the B&O
BeoNut since '75
johnrb47
Posts 3
Thanks so much elephant
All is sweet
Page 1 of 1 (5 items) | RSS
