BeoSound 5 Encore table stand
This post has 4 Replies | 2 Followers
KMA
Posts 621
KMA Posted: Wed, Mar 28 2012 9:27 PM
Hello all,
I got my Beosound 5 Encore last week, and have now just about set it up. I have one (probably very stupid) question about the table stand:
Having attached it, how do I detach it? I've rotated the aluminum holster to release position (the very bottom cylinder at the base of the BeoSound) but I just cannot get the stand off, even though the bottom cylinder is not locking it anymore. I'm afraid to use too much force detaching the stand, so what's the trick?  Feels as if though the base is permanently fixed to the BeoSound, but that cannot be the case because there might be a reason to access the cables.
KMA
B&O product history since 1991: Ridiculously long to list in a signature.
mbee
Paris, France
Posts 1,842
mbee replied on Wed, Mar 28 2012 9:46 PM
Put a pen o the little hole in the ring, and then it will go further, allowing you to detach the Beosound from the stand
KMA
Posts 621
KMA replied on Wed, Mar 28 2012 9:52 PM
mbee:
Thanks mbee,
I did, and rotated the bottom cylinder to the release position. But still the stand is very firmly fixed to the BeoSound....
KMA
mbee
Paris, France
Posts 1,842
mbee replied on Wed, Mar 28 2012 9:56 PM
Ok, so you just need to turn the Beosound a bit, clockwise, and then lift it gently
KMA
Posts 621
KMA replied on Wed, Mar 28 2012 10:05 PM
Thanks, the pen actually did it: I just had to use it *after* I had already rotated the bottom cylinder loose.
Got it now :)
KMA
Page 1 of 1 (5 items) | RSS
