Maybe not for General forum ... but then there is a WD vs ATV discussion on here, so here goes.
For some time I have been looking at how to jailbreak a spare ATV to gain access to our slightly underused PLEX library ... but every time I looked at how "complex" (for me) the task seemed my eyes would glaze over and I would fall asleep ....
Today a different approach was announced in the Macworld/PLEX communities so in a spare 30 minutes this evening I thought I would try it .... and BLIMEY IT WORKED (so far I have only played one of my captured music DVDs and flicked through a few Apple Trailers including the latest just added online (this is significant given what you will see below) and it has been rock solid.
Will it be stable over time ?
Will it survive SWMBO at the hand on the Beo4 ?
Will it get nuked by the next ATV update / the next Mac update / the next PLEX update ?
All good questions for which the answer lies in the future
But for now, take a look at the following article, screen shots, and simple (look, I could follow them, so they must be simple - or was I just lucky tonight ?) instructions !
http://elan.plexapp.com/2013/06/04/introducing-plexconnect-an-appletv-client-which-thinks-different/
http://forums.plexapp.com/index.php/topic/69410-please-read-before-posting/
https://github.com/iBaa/PlexConnect/wiki/OSX-and-ATV-with-5.2-firmware-and-ethernet-internet-connection-installation-guide
Good luck .... and I *think* it would be easy to backout ... provided you take notes of the before and after settings on the ATV !
BeoNut since '75
OK - I will calm down as it does have some glitches
Most of my captured materials work (although I am getting buffering issues on one file at the moment - from memory it is a downloaded flash recording), but I think the main problem (just before going to bed) lies with iTunes files !
