Hi all
I have obtained this lovery amp and besides one duff output stage and a re capp required the on off sw is faulty it will not lock down. It lools like the plastic has worn a way ( the sw works you have to hold the sw down ) and it is the sw at fault as its in bits on the bench !!!!! So my question is does anybody have such a item so I can bring this beauty back to life Otherwise it will be lost for ever and that would be a shame
Based in the UK
Thanking you in advance Ron
Not exactly aware of what you mean. But the switches itself can be faulty. If so, you can take the switch apart, so you swap the (burned) contacts.
Hi Beobuddy
Thanks for the reply ( I am having major connection problems with my broadband so sorry for the delay )
The problem is not the contacts of the switch that part works fine their is a white plastic pin in front of the body of the switch and it is worn flat on one side and this is what should makes it lock down ?? so I don't actually need a whole switch just the white plastic piece
I tried to upload a photo but gave up ??
Thanks for you reply
Ron
