BeoMaster 7000 has a (badly) preconfigured volume profile
makeITfunctional
Posts 8
makeITfunctional Posted: Fri, Jun 28 2013 3:45 PM
Hello, Beoworld!
I recently acquired a BeoMaster 7000 and I've connected my BeoLab 3s and BeoLab 11 into the system without issue.
Everything works perfectly, except each time I use the system I must change the default volume settings from a badly preconfigured state that the prior owner must have saved. Here's what I mean:
  • The default volume level is 28 (which I'm fine with)
  • The default balance favors the right speakers by 2 (I'd like to have them centered)
  • The default bass is +6 (I'd like to have this at 0)
  • The default treble is at -6 (I've like to have this at 0 as well).
Is there a way to clear these values and/or do a master reset on the system?  The only remotes I have available to me are the Beo4 and the Beolink 4000.
Thanks so much!
Søren Hammer
Denmark
Posts 953
On the Beo4, press the SOUND button (under LIST) until your parameters show on the Beomaster's display. Then correct them with the ^/v buttons and save with pressing store twice.
Vinyl records, cassettes, open reel, valve amplifiers and film photography.
Anders Jørgensen
Denmark
Posts 350
I have never heard of a Beolink 4000 but the 1000 is more simple to use for storing settings.
Set it to your liking and then sound, store, store
It is a bit more complicated on a Beo4 as you have to locate it on  list first but the instructions for doing are the same regarding of Beo4 or Beolink 1000.
makeITfunctional
Posts 8
Thanks, Søren Hammer and Friedmett!
I'll give this a try tonight and let you know.
Playdrv4me
USA
Posts 477
Playdrv4me replied on Sat, Jun 29 2013 12:24 AM
This is yet another one of those strange "Beo-isms" that I see comes up a lot, as it certainly got me a few times... The whole "preset startup values" thing. Never really understood why B&O just didn't stick with the convention of leaving settings where they are when the product is shut off. Maybe it plays better with Masterlinked systems or something, but I know I almost killed a pair of BL1s because of this once (a BeoSound 9000 that was set to like 55) and for whatever reason the BL5s were set loud enough that I could hear faint hiss in the background which gave it away before I really pumped any music to them. Very dangerous for the speaker drivers.
makeITfunctional
Posts 8
Resolved by following the suggestions in this post!  (Adjusting the sounds to my preferences and then pressing sound, store, store on the remote)
Thanks so much!
I completely agree with you, Playdrv4me -- at the very least, they should have an option to offer to remember the settings from the last session.
Page 1 of 1 (6 items) | RSS
