Smartphone control of B&O with Harmony Hub
This post has 11 Replies | 2 Followers
beojeff
USA
Posts 2,012
beojeff Posted: Fri, Jun 28 2013 4:02 PM
I was researching the Logitech Harmony Ultimate Hub that is going to be available this August and see the potential as a solution for smartphone app control of B&O without the Masterlink Gateway. The hub can convert wi-fi commands from its smartphone app into IR and Bluetooth commands. I checked its database of supported devices and found the BeoSystem 3 and BeoSound 5 listed. It seems that this could be a way to convert and send commands from a smartphone to the B&O IR receiver via the hub. The same app would also provide control of the new Philips Hue lighting system.
Any thoughts on this?
linder
United States
Posts 983
linder replied on Fri, Jun 28 2013 5:00 PM
Thanks for posting this.  I already have a few wifi remotely controlled lights using an iPhone app.  I am definitely going to buy this to control my Beosound 5.
Razlaw
Posts 4,345
Razlaw replied on Fri, Jun 28 2013 7:22 PM
Interesting. I was looking briefly at it and it appears to be available now? I see it on both Amazon and BestBuy sites and BestBuy shows it in stock at my local store.
Or am I seeing an old model?
beojeff
USA
Posts 2,012
beojeff replied on Fri, Jun 28 2013 7:34 PM
Razlaw:
My understanding is that the hub is currently available bundled with a Harmony remote. However, in August, the hub will be available separately (and more inexpensively) without the Harmony remote for those who just want to use a smartphone as their remote without using the extra Harmony remote.
This seems to be a solution in reverse of the Masterlink Gateway solution: instead of using the B&O IR to connect to the MLGW to connect to the smartphone, we would be using the smartphone to connect to the hub to then forward IR control to the B&O IR receiver.
Razlaw
Posts 4,345
Razlaw replied on Fri, Jun 28 2013 7:36 PM
Beosound 3000, Avant and BV 10 are also in database. I assume other are also but I only checked these.
Razlaw
Posts 4,345
Razlaw replied on Fri, Jun 28 2013 7:37 PM
beojeff:
That makes sense. Thanks!
Ƨcɑɽɑɱɑnɡɑ
Khao Phing Kan
Posts 6,662
Razlaw:
In my Harmony experience, I have yet to find ANY B&o (back to, but not including the ultrasonics) that could not be controlled -regardless of their existence (or not) in a Logitech database. That said, some pieces may require manual learning.
  • One B&o bottle opener
  • One fancy gun
Playdrv4me
USA
Posts 477
Playdrv4me replied on Sat, Jun 29 2013 12:41 AM
ɓʋɾɑɳɫɘɮ:
Razlaw:
Beomaster 8000 couldn't be controlled with my (admittedly low end) Harmony 300i despite being in the database.
All the other B&O gear works fine, though with this remote it sends volume commands in bunches of 3 or 4 up or down instead of one interval. I'm sure I could probably alter the command list or something even further but it works for now.
Ƨcɑɽɑɱɑnɡɑ
Khao Phing Kan
Posts 6,662
Playdrv4me:
Interesting! I had no problems with the 8000 and my 880 remotes. In fact, short of the FILTERS and perhaps another function or two, I recall it pretty much working right off the bat. My guess is that the difference must be in the physical remote and not the programming, though that seems illogical. I would suggest trying the provided programming for another period piece, or resort to trying the "LEARN" utility and your 8000 terminal if you wanted to have another try.
Regarding the "4 UP/DN" with volume ... this only happens on my B&o and none of my Kikoniko. Some rainy day I will tackle that and will be happy to share!
  • One fancy gun
lano
Posts 161
lano replied on Sun, Jun 30 2013 9:33 AM
Hi, this could also be an alternative:
http://www.mammutbox.com
I havn't tried it myself, but I do like the Beolink app.
Bv7Mk3
uk
Posts 781
Bv7Mk3 replied on Sun, Jun 30 2013 11:39 AM
Looks good Big Smile Wonder what the price of the units is?
mjmedlo
Posts 922
mjmedlo replied on Sun, Jun 30 2013 3:37 PM
Aren't all of the b&o commands the same?
I'd you have one video(bs3) and one audio(bs3k)
You should be able to control anything I think.
Page 1 of 1 (12 items) | RSS
