Beovision avant 32 DVD
This post has 4 Replies | 0 Followers
bishop8883
Posts 2
bishop8883 Posted: Sat, Jun 29 2013 4:56 PM
Hi - I have just been given an  B & O Beovision avant 32 DVD but i cant get the picture up - only the sound !
Please advise as I don't have any instructions
Cheers
Steve
Peter
Earsdon
Posts 11,991
Peter replied on Sun, Jun 30 2013 10:14 AM
Not good. Could be a component failure if you are lucky but might be the tube, which may be why you were given it!!What are you attaching to it though? Do you get static if you select TV? Or is the screen just black?
Peter
bishop8883
Posts 2
bishop8883 replied on Sun, Jun 30 2013 10:25 AM
Thanks for your response. There is no static when it turns on and I am simply using it as it - nothing attached -Just through the t.v aerial socket
Please advise !!
Steve
Millemissen
Flensborg, Denmark
Posts 14,680
What kind of tv arial do you have - it must be an analog signal to see anything on the Avant.
Where are you located?
Do you get the menu on the screen, when you press 'menu'?
How about using the DVD drive - still nothing?
Greetings Millemissen
bayerische
Ekenäs, Finland
Posts 4,770
Try and access the menu, I don't think the TV will show "noise", it just goes black without a signal. If it's the tube that is broken, it's an expensive fix and these usually end up as "landfill" at that point. Sad
Too long to list....
Page 1 of 1 (5 items) | RSS
