Hi - I have just been given an B & O Beovision avant 32 DVD but i cant get the picture up - only the sound !
Please advise as I don't have any instructions
Cheers
Steve
Not good. Could be a component failure if you are lucky but might be the tube, which may be why you were given it!!What are you attaching to it though? Do you get static if you select TV? Or is the screen just black?
Peter
Thanks for your response. There is no static when it turns on and I am simply using it as it - nothing attached -Just through the t.v aerial socket
Please advise !!
What kind of tv arial do you have - it must be an analog signal to see anything on the Avant.
Where are you located?
Do you get the menu on the screen, when you press 'menu'?
How about using the DVD drive - still nothing?
Greetings Millemissen
Try and access the menu, I don't think the TV will show "noise", it just goes black without a signal. If it's the tube that is broken, it's an expensive fix and these usually end up as "landfill" at that point.
Too long to list....
