Upgrade beomaster 5 harddisk
This post has 210 Replies | 11 Followers
Michael
Copenhagen
Posts 89
Michael replied on Sun, Nov 1 2015 11:26 AM
my macbook is a pro medio 2012 i7 2.3 Ghz 16 GB 256 GB SSD
but i can borrow a pc if that is easier
cheers
Michael
it is already between 25-50 % done after just 45 minutes
oh damn i just saw i am using a 3 TB HD but i guess i can just resize to it 2 TB or shall i get a 2 TB HD
MicTheCat
Denmark
Posts 10
Silver Member
MicTheCat replied on Sun, Nov 1 2015 12:45 PM
Michael. You can actually use BM5 for the cloning process. I used Hirens Boot CD installed on a USB memory stick and attached external display to BM5 and used Patition Magic on Hirens Boot CD. See my post in this tread page one. And Google Hirens for procedure to make the USB stick
have fun ;-)
MicTheCat
Denmark
Posts 10
Silver Member
have fun ;-)
Michael
Copenhagen
Posts 89
Michael replied on Sun, Nov 1 2015 1:29 PM
well actually the clone box says the clone is finished now i just need to resize the HD
anyone than recommend a good program for that either for windows or mac is it freeware
well let you know about my progress
cheers
Michael
Michael
Copenhagen
Posts 89
Michael replied on Sun, Nov 1 2015 2:03 PM
well the clone said it was done but.
when i start the Beo5 it starts with the normal screen wait the 9 seconds and then it flashes a blue screen and then it restarts Sad
dont know if it is cause it is a 3 TB HD with around 2 TB of unused space haven't found the program to use yet to merge / resize the partition
any idea what can have gone wrong ?
Michael
riverstyx
SouthWest UK
Posts 938
Hi Michael,
Unfortunately, as I mentioned in an earlier post, 2TB is the upper limit as XP is unable to address anything larger than that. It doesn't matter that the partitioned space is below 2TB as XP will still be unable to boot from a larger disk.
Kind regards
Martin.
Michael
Copenhagen
Posts 89
Michael replied on Sun, Nov 1 2015 4:26 PM
ok i will order a 2 TB HD right away
thanks alot again again and again [:)Big Smile
Michael
riverstyx
SouthWest UK
Posts 938
No worries.
It's the western digital WD20EURX 2TB AV-GP HDD that I used as it is the same series as the 1TB disk that B&O install. Others should work but I felt sticking with the same drive series would help to eliminate any possible problems, especially since some of the higher rpm drives can be both noisy and generate more heat.
Martin.
MicTheCat
Denmark
Posts 10
Silver Member
I would recomment installing an SSD and put Music on NAS. I have done that over a year ago and BM5 is very responsive as it is suppposed to be but never was with the original HDD. My SSD is a 256 GB one and its fine for the systems but no Music files. All on NAS and it works as a charm
Michael
Copenhagen
Posts 89
Michael replied on Sun, Nov 1 2015 6:42 PM
well i have considered that but i have right now a Qnap TS-251 with around 44000 flac files on and when it comes to 17000 files no more covers been talking alot with B&O about it not that it helped so much
been trying for 2 weeks to get it to work but i have given up but if it works with a 256 GB ssd with all my files i will serious consider that
Micthecat have many files do you have with covers etc etc
cheers
Michael
Michael
Copenhagen
Posts 89
Michael replied on Tue, Nov 3 2015 4:05 PM
I just clone my hd to a 2 TB but when i try to resize / format the unallocated space it would let me do it
any good idea what program to use
cheers
Michael
Michael
Copenhagen
Posts 89
Michael replied on Tue, Nov 3 2015 4:07 PM
I just clone my hd to a 2 TB but when i try to resize / format the unallocated space it would not let me do it
cheers
Michael
riverstyx
SouthWest UK
Posts 938
riverstyx replied on Wed, Nov 4 2015 10:29 AM
Hi Michael,
Firstly, it's worth checking that the drive will boot successfully before going any further if you haven't already done so.
I'm not at home right now so I can't check and might be wrong, but from memory I think there is another partition after the data partition that you want to expand so that will need to be moved to the end of the disk first. You can use gparted both to move this partition and then to expand the data partition.
Kind regards,
Martin.
Michael
Copenhagen
Posts 89
Michael replied on Wed, Nov 4 2015 11:12 AM
Hi Martin,
I have testet the clone copy and that one works perfectly
i expanded the Data Partition and then i tried then i got an error then i delete the Data partition this time i boots perfectly but when i try to go into the menu where i choose storage etc.  it it reboots
i can see on the original there is 10 mb of unallocated space but dont think that is the problem
so right now i am bit lost
i used mini tool to extend and format the partition
anyway i will do a brand new cloning and try to use it cause i am really not sure i have to got in the menu i mentioned above
Michael
Michael
Copenhagen
Posts 89
Michael replied on Wed, Nov 4 2015 1:43 PM
Hi Again,
i just completed the cloning and inserted the disk in beomaster 5 and it works perfectly listening to music right now from the cloned disk.
after i expanded the disk last time it is like the settings is all gone the language was english now it is danish
so i am pretty sure it is when i try to expand the disk i do something wrong.
hope you can help me me the last few steps to get it working Big Smile
cheers
Michael
riverstyx
SouthWest UK
Posts 938
Hi Michael,
You want to resize the partition without reformatting it too as this will wipe all data (which is why your language settings changed etc).
I'm not familiar with the software you are using but hopefully it will allow you to do this.
I'll do a complete write-up of the entire process when I have some free time but hopefully this will help in the the meantime.
Kind regards,
Martin.
Michael
Copenhagen
Posts 89
Michael replied on Wed, Nov 4 2015 4:03 PM
Hi again,
which tools did you use Gpart ?
did you extend or resize ?  i have extended it as the freeware of mini tool partition dont support that
cheers
Michael
riverstyx
SouthWest UK
Posts 938
riverstyx replied on Wed, Nov 4 2015 10:23 PM
Hi Michael,
Michael:
Yes, I used GParted.
Michael:
This might be a case of different tools calling things by different names. There are four partitions on the original BM5 hard disk, so after cloning to a larger disk you will have:
[Recovery] [System] [Data] [BM System] (unallocated space)
first you need to move the BM System partition to the end of the disk, then you will have:
[Recovery] [System] [Data] (unallocated space) [BM System]
next, you need to resize the Data partition to fill the unallocated space, so that you end up with:
At that stage you should be ready to go.
See if you can do the above with the software you are using and let me know how you get on.
Kind Regards,
Martin.
Michael
Copenhagen
Posts 89
Michael replied on Wed, Nov 4 2015 10:51 PM
i have downloaded the gparted and burn it on CD and boot up on the CD
but i just can't get it to move to the end of the disk  i am trying the resize move option
and been reading the help file on g.parted.org but it just won't do it
will try some of the other tools
michael
riverstyx
SouthWest UK
Posts 938
riverstyx replied on Wed, Nov 4 2015 10:55 PM
You should just be able to drag the slider to the right (clicking and dragging from the middle of the block, otherwise you will resize it instead).
Alternatively, you can just type a zero in the "free space following" box.
Best on an older system like the BM5 to select to alight to: "cylinder" too.
Martin.
Michael
Copenhagen
Posts 89
Michael replied on Wed, Nov 4 2015 11:00 PM
Hi Martin,
thanks a lot will try that now
will post my progress
cheers
Michael
Michael
Copenhagen
Posts 89
Michael replied on Wed, Nov 4 2015 11:14 PM
if i just type 0 it won't let me move it
right now i have
free space o
new size 996
free space following miB 953869
allign to Cylinder
riverstyx
SouthWest UK
Posts 938
riverstyx replied on Wed, Nov 4 2015 11:19 PM
It won't let you delete the 953869 and type '0' instead in the free space following box?
Michael
Copenhagen
Posts 89
Michael replied on Wed, Nov 4 2015 11:26 PM
yes i just need to read what you wrote sorry
but i got a 2.49 off unallocated space but now i growning the data to 1.81 GB
so now i have Recovery system data bmsystem and unallocated space at 2.49
should i resize the bmsystem back or ?
Michael
riverstyx
SouthWest UK
Posts 938
riverstyx replied on Wed, Nov 4 2015 11:34 PM
Okay, let me know first whether you have already clicked "Apply" on the main screen?
If you haven't, then DON'T, as this means we still have time to undo the changes and try again...
Michael
Copenhagen
Posts 89
Michael replied on Wed, Nov 4 2015 11:34 PM
yes i clicked apply
riverstyx
SouthWest UK
Posts 938
riverstyx replied on Wed, Nov 4 2015 11:35 PM
(If you've already applied the changes, then we can still sort this out, but I need to know which way to guide you)
Michael
Copenhagen
Posts 89
Michael replied on Wed, Nov 4 2015 11:36 PM
yes i have applied the changes let me know what you need to know to fix it
riverstyx
SouthWest UK
Posts 938
riverstyx replied on Wed, Nov 4 2015 11:36 PM
Okay, no problem.
Is the unallocated space shown after the BM System partition (ie at the bottom of the list)?
Michael
Copenhagen
Posts 89
Michael replied on Wed, Nov 4 2015 11:37 PM
yes it is
recovery system data bmsystem unallocated
riverstyx
SouthWest UK
Posts 938
riverstyx replied on Wed, Nov 4 2015 11:41 PM
Okay, I presume you meant you'd grown the Data partition to 1.81TB (not GB)?
Highlight BM System again and click 'resize/move' - see if it will let you move it further to the right, or let me know what values are show in the boxes again.
Michael
Copenhagen
Posts 89
Michael replied on Wed, Nov 4 2015 11:43 PM
hehe yeah 1,8 TB
free space preceding 977
new size 22
free space following 0
allign to cylinder
riverstyx
SouthWest UK
Posts 938
riverstyx replied on Wed, Nov 4 2015 11:48 PM
Okay, looks like you've shrunk (or are shrinking) The BM-System partition, cos it's size should be just under 1000MiB. Try dragging the left hand edge of the green bar all the way to the left, so that it ends up showing:
Free space preceeding: 0
new size: 999 (approx)
Free space following: 0
Michael
Copenhagen
Posts 89
Michael replied on Wed, Nov 4 2015 11:50 PM
can i just type the numbers in ?
riverstyx
SouthWest UK
Posts 938
riverstyx replied on Wed, Nov 4 2015 11:52 PM
probably.. I know that preceeding / following tend to change each other, but if you type 1000 in the size box it'll probably work (or tell you the maximum)
riverstyx
SouthWest UK
Posts 938
riverstyx replied on Wed, Nov 4 2015 11:53 PM
Once you've done that (and before clicking apply), let me know what is shown on the main screen ('partition name' and 'size' for each) and whether there is still any unallocated space showing.
Michael
Copenhagen
Posts 89
Michael replied on Wed, Nov 4 2015 11:54 PM
ok i just type 1000 in and it change it 999
Michael
Copenhagen
Posts 89
Michael replied on Wed, Nov 4 2015 11:55 PM
Recovery 1,95 GIB
system 4.89 GIB
data 1.81 TIB
BM-System 998,62
no more unallocated space
riverstyx
SouthWest UK
Posts 938
riverstyx replied on Wed, Nov 4 2015 11:56 PM
Perfect, go ahead and click 'Apply' and let it do it's thing Smile
riverstyx
SouthWest UK
Posts 938
riverstyx replied on Wed, Nov 4 2015 11:58 PM
Are you doing this on the BM5 itself, or do you need to reinstall the hard disk in the BM5 after it has finished?
Page 3 of 6 (211 items) < Previous 1 2 3 4 5 Next > ... Last » | RSS
DigiCert Secured Site Seal
