BeoLab 2 Possible Fault
This post has 4 Replies | 0 Followers
jkhamler
Posts 286
jkhamler Posted: Wed, Jul 3 2013 10:04 AM
Hi all,
My BeoLab 2 has just started to play up. It powers up as normal but it hardly emits any sound. If I go into the config menu of my V1 and fire some white noise through it, it can be heard but it is very faint. Has anybody experienced any similar problems? It's a 2007/8 model which I bought used a couple of years ago.
Cheers, Jon
valve1
The south of France and occasionally Dublin Ireland
Posts 1,502
valve1 replied on Thu, Jul 4 2013 7:18 AM
Have you tried the bl2 on other sources ?
bayerische
Ekenäs, Finland
Posts 4,770
Try it with another source, if it's the same then most likely there's something wrong with it.
Is the cable OK?
Too long to list....
jkhamler
Posts 286
Guys, sorry, false alarm - I had messed up the settings on the V1 for that speaker group playing around with bass management. I reset them and all was fine! Mods feel free to delete this thread...
Cheers!
Jon
Opman
Wilmslow, Cheshire
Posts 443
Opman replied on Thu, Jul 4 2013 10:36 AM
At the risk of applying the "commentators curse", I don't recall EVER seeing a faulty BeoLab2.
Opman
Page 1 of 1 (5 items) | RSS
