Hi all,
My BeoLab 2 has just started to play up. It powers up as normal but it hardly emits any sound. If I go into the config menu of my V1 and fire some white noise through it, it can be heard but it is very faint. Has anybody experienced any similar problems? It's a 2007/8 model which I bought used a couple of years ago.
Cheers, Jon
Have you tried the bl2 on other sources ?
Try it with another source, if it's the same then most likely there's something wrong with it.
Is the cable OK?
Too long to list....
Guys, sorry, false alarm - I had messed up the settings on the V1 for that speaker group playing around with bass management. I reset them and all was fine! Mods feel free to delete this thread...
Cheers!
Jon
At the risk of applying the "commentators curse", I don't recall EVER seeing a faulty BeoLab2.
Opman
