BeoSound 9000 initial volume too loud
This post has 13 Replies | 1 Follower
max20
Posts 6
max20 Posted: Fri, Jul 5 2013 1:56 PM
Hi! Thanks for this great forum!
My problem: when turning on the initial volume of the speakers is 40 which is way too loud for me.
My setup... one Beo4 Remote and:
Room 1:
BeoSound 9000
BeoLink Active
Pair of BeoLab 4000
Room 2:
BeoLink Active
Pair of BeoLab 3000
Now as I said when turning on either of the speakers the volume is 40 which is very loud. I can not configure the volume through Beo4 - only Bass, Loudness, etc. are availible.
I opened the control panel of the BeoSound 9000 and tried to lower the volume. The LCD shows a lower volume of e.g. 20 which I can save. But it has absolutely no effect.
How can I set a global initial volume of 20 for my speakers?
Thanks for your help.
bayerische
Ekenäs, Finland
Posts 4,770
When you set bass/treble volume level will be set.
Too long to list....
max20
Posts 6
max20 replied on Fri, Jul 5 2013 6:08 PM
Ok the volume level is set. But now I have the following Problem:
The volume is still very loud when turning it on, and Volume 0 is not silent, but only lower volume. It just shifted the volume range.
bayerische
Ekenäs, Finland
Posts 4,770
Sounds like you have a problem with your BS9000.
max20
Posts 6
max20 replied on Fri, Jul 5 2013 6:15 PM
Is it possible that this is a problem with the masterlink configruation?
bayerische
Ekenäs, Finland
Posts 4,770
max20:
According to my memory you also need to set each masterlink set separately, not only the master. You can have a loud kitchen so to speak, and a silent bedroom.
Could your problem be there?
max20
Posts 6
max20 replied on Fri, Jul 5 2013 7:26 PM
Thanks, yes that is a valid point.
How do I select a masterlink set separtely?
Beobuddy
Utrecht, The Netherlands
Posts 3,972
As you are using beolink active twice, the initial volume is stored in these actives. Not on the master itself, as you've propably haven't connected any speakers to it's powerlink.
Try using A.Setup on the Beo4 (you probably have to add that function) and use S.Store.
max20
Posts 6
max20 replied on Fri, Jul 5 2013 7:54 PM
hi beobuddy thanks for your reply.
i only get bass treble and loudness when using a.setup on my beo4.
a volume setting is never displayed.
which "v.opt" "a.opt" "l.opt" config should i use with my setup?
Beobuddy
Posts 3,972
After using A.Setup (press Go) isn't there a S.Store option after Bass and Treble by pressing the list button?
Choose S.Store and press Go.
By using the beolink active, settings aren't visible.
Beobuddy
Posts 3,972
If I understand correctly, you have a BS9000 connected with two Beolink actives. These actives have their own ir-eye.
Pointing the Beo4 at these ir-eye(s) will set the beolink active. i also  assume that your speakers are located in a different area than where the BS9000 is located? Correct?
max20
Posts 6
max20 replied on Sat, Jul 6 2013 9:01 AM
Thaaaaaaaaaaaaanks BeoBuddy!!!!!!!!!!!!!!!!!!!!!!
It worked!!!! You rock!!!
bayerische
Ekenäs, Finland
Posts 4,770
Glad you got it to work.
Beobuddy
Posts 3,972
max20:
Your welcome.
Glad to read that your problem is solved. Any feedback is always appreciated Yes - thumbs up
Page 1 of 1 (14 items) | RSS
