Hi everybody
I plugged my headphone on my bv11 (on top of it) and I have absolutely no sound.
I still have the sound on the tv.
The dealer told me that I could use an headphone and the sound from the tv at the same time.
If you own a bv11 please let me know how I can activate the headphone.
I tried two different headphone and they both work on other devices.
Thanks in advance for your advice.
Best regards
olivier
4 beolab 5, beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2, 2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
B&O have implemented an illogical, absurd, counter intuitive and complete pain in the @@s headphone protocol.
This is how it should be - plug headphones in, tv speakers automatically mute, adjust volume to suit.
Instead you have to mute the tv speakers.
Menu - Setup - Sound - Sound Adjustment ....scroll down to Headphones...use the toggle button to adjust the headphone output. My guess is your Headphone slider is set very low or all the way down.
Utterly bonkers and super useless way of doing things.
You will have output from tv speakers and headphones so don't forget to mute the tv speakers.
Grrrr, tut, moan.
A software update to fix this please!
Hi
Thanks a lot for your answer !!
