hello all,
just looking at a Beomaster 8000 - Typ 1903, which is the US version
after studying the service manual and the assigned diagram of the power supply
my question: is there a way of setting this one up for operation with 240 VAC ?
I noticed the diagram show the various types, incl. typ 1905 for 240 VAC and the different rating of fuses in section 7 .
I can not imagine changing the fuses there will give you the go ahead for operation with 240VAC ??
perhaps one of you experts could enlighten me ? :-)
thank you kindly for your suggestion - ALF
You will either need a suitably rated step down transformer or some UK spec transformers out of a scrap unit I am afraid.
Olly
