Beovision 10-46 if audio selected after video the picture stayes on ??
This post has 30 Replies | 2 Followers
georgey007
Posts 74
georgey007 Posted: Fri, Jul 26 2013 1:47 PM
Hi there
I have a beovision 10-46 in my living room on option 6 and a bs 9000 option 0 and a beovision 10-32 option 2 in the dinning room.
connection works fine but if i select a audio feed after warching tv the radio comes on but the tv is still showen. To switch of the picture i have first to switch off the tv an then switch it in radio on again.
any sugestions ?
regards
Raeuber
Germany
Posts 2,542
Raeuber replied on Fri, Jul 26 2013 1:59 PM
Hi georgey007,
if you press RADIO on Beo4 in your living room (BV 10-46) you should hear radio of your BS 9000 and the picture should switch off automaticly.
Greetings
Räuber
Millemissen
Flensborg, Denmark
Posts 14,680
Why the option 6 in the livingroom tv together wth the 9000?
Why not option 2? - and option 6 for the 10-32 (I suppose they are close together and might  both be reached with the Beo4 otherweise)?
MartinW
Posts 389
MartinW replied on Fri, Jul 26 2013 2:55 PM
Hi, are you using Beo4 or Beo5/6?
Raeuber
Germany
Posts 2,542
Raeuber replied on Fri, Jul 26 2013 3:11 PM
Millemissen:
That's correct, dear Millemissen. But if I understood it right, BS 9000 and BV 10-32 are located together in ONE room (dinning room). In this case the option settings are correct.
Greetings
Räuber
BeoHut
Posts 482
BeoHut replied on Fri, Jul 26 2013 3:27 PM
Did you tried it with the AV-command (like AV-RADIO) on your BV10-46? Only audiosignals will be transported and the tv (= sreen) stays off. Just a suggestion?
vikinger
Vestri Kirkjubyr, UK
Posts 5,422
vikinger replied on Fri, Jul 26 2013 4:18 PM
This sounds like the reverse of my BV11 problem.
Sometimes  when I switch from radio to TV the radio still picture (even if previously picture muted) comes on with the TV channel sound. I have to turn the TV off and wait a couple of minutes and then start again. In my case I think it's some sort of software issue combined with a locking-up of the internal tuner module.
My problem only happens when the audio is coming first from the internal TV 'Freeview' tuner.... my Beocenter etc Is all now in a separate room and not connected to the BV11 which will not work with Masterlink.
Graham
Millemissen
Flensborg, Denmark
Posts 14,680
"That's correct, dear Millemissen. But if I understood it right, BS 9000 and BV 10-32 are located together in ONE room (dinning room). In this case the option settings are correct."
Dear Raueber,
well, I did understand that the audio system 'is located' with the BV10-46 - most people would do so! - and that the 10-32 is a link-tv
Untill it is clear what Georgy wants, we don't come any further.
Greetings Millemissen
BeoHut
Posts 482
BeoHut replied on Fri, Jul 26 2013 4:34 PM
Millemissen:
Correct. Gregory has to make us clear what is located in the livingroom and in the diningroom. And is the equipment connected via ML?
That would make it a lot easier to tell Gregory how he can set the options and he has to make us clear what he wants. I think it is better to wait for a reaction, before we know how he has setup his audio and video. Perhaps forget my solution till sofar.
georgey007
Posts 74
Hi
wow i must say a lot response :)
ok it seams that i have to lay out my whole setup.
In the dinnig room ( kitchen )
one beosound 9000 in option 0 as audio master
one beovision 10-32 as videomaster option 2 with beolab 4000 conectedn
as an extra listen zone beolink aktiv with pair of beolab 8000 in option 4
one beo4 as remote for this room
in the living room one beovision 10-46 with 1 beolab 1 2 beolab 6000 and 2 beolab4 in option 6
Bedroom one beovision 10-40 with beolab 1 in option 6
bathroom one beolink passiv in option 6
all with beo4 and masterlinkgateway
the audio master is playing well everywhere even in the livingroom
only thing is that the picture on the tv stays on when i switch to audio and istnt switching the display to black and after a while off
the 2 other beovision 10 are behaving as they should
regards
georgey007
Posts 74
All connected via ml of course
DoubleU
Posts 562
DoubleU replied on Fri, Jul 26 2013 6:25 PM
I would start with leaving the 10-46 not powered for a few minutes. If that doesn't work, a reset to default and put it back in option 6.
Long shot but worth a try.
Millemissen
Flensborg, Denmark
Posts 14,680
"wow i must say a lot response :)"
That is how we are Stick out tongue
Thanks for your details - it is always easier, if you know how things are connected and the location.
Very nice setup - indeed!
Just to be sure I did a test - I have something similar to your setup.
My BV8-40 turns off - I mean turns the picture off after for a couple of second having shown the new source e.g. 'CD'. And the Speakers constallation changes according to my preferences.
I had the BV8-40 as a Link-tv in another room earlier and it behaved exactly the same!
This of cource is no answer to your question, but just to describe the 'right' behaviour.
Did you rearrange your setup recently, did you do 'some work' at the MasterLink?
Did you changed anything in a ML JUNCTION-box? Could be a place to start looking?
georgey007
Posts 74
Hmmm
i unpluged everything multible times ! But reset how do i do that ?
Yes i relocated and the whole wirering was done from skatch.
Raeuber
Germany
Posts 2,542
Raeuber replied on Fri, Jul 26 2013 7:04 PM
If BV 10-32 and 10-40 are showing the correct behaviour and only BV 10-46 not, I would check the following:
- Masterlink connections of the masterlink cable going from BV 10-46 into junction box
- Have all BV 10 the same software version installed?
- Factory reset of BV 10-46 (in the hidden service menue)
Good luck!
/Räuber
Raeuber
Germany
Posts 2,542
Raeuber replied on Fri, Jul 26 2013 7:19 PM
Millemissen:
BTW (off topic): It would be not so easy to realize this setup without Masterlink, but with Netlink without any sound delays!
georgey007
Posts 74
Thank u
georgey007
Posts 74
The ml cabel i will change!
how do i get into the hidden menue
Regards
Raeuber
Germany
Posts 2,542
Raeuber replied on Fri, Jul 26 2013 8:13 PM
georgey007:
Regards
Press MENU on Beo4 (twice if you have a HD module), then mark OPTIONS, finally press 0 0 GO. Then you will find the item FACTORY RESET. But be aware that you have to set ALL settings of your BV 10-46 (like a new TV)!
DoubleU
Posts 562
DoubleU replied on Fri, Jul 26 2013 8:13 PM
delteted
Raeuber
Germany
Posts 2,542
Raeuber replied on Fri, Jul 26 2013 8:17 PM
Probably you can replace the BV 10-46 by your BV 10-32 or BV 10-40. Then you can verify if the problem is caused by BV 10-46 or Masterlink connection.
MartinW
Posts 389
MartinW replied on Fri, Jul 26 2013 8:59 PM
Its a strange one! I have seen this caused by faulty ml wiring so I would check that out. Make sure all three ground wires are connected and if you are using an ml junction box, make sure those ground wires are not shorting out some other colours in the junction box.
Millemissen
Flensborg, Denmark
Posts 14,680
Wow, so much going on here - while I took a leave and watched some tele Embarrassed
I would start checking the junction box/es as Martin says.
N.B. Were changes made to the MLGW when relocated?
Did it work with the 10-46 before relocating?
Off topic: Raeuber - how shall I understand your 'off topic comment"?
Greetings MM
Raeuber
Germany
Posts 2,542
Raeuber replied on Sat, Jul 27 2013 12:38 AM
Millemissen:
Greetings MM
Hi Millemissen,
I only wanted to mention that it is so easy to connect so many B&O devices via masterlink, the masterlink cable is the only necessary "pipeline" to realise this. If you would replace all BV 10 with BV 11 it would not be so easy anymore.
Greetings
Räuber
Millemissen
Flensborg, Denmark
Posts 14,680
Hi Raeuber,
I know this a 'matter of controverse discussion' for you.
With the NL/ML Converter (and it needed the delay box) you can do exactly the same...
...and enjoy the possibilities of the new engine in the BV11/V1/BSys4 and forthcoming products.
Best of two worlds, I would say Big Smile
But we shouldn't hijack this post - I am still curious to hear more from Georgy.
Greetings Millemaissen
BeoMegaMan
Posts 601
What software is being run and what MK is your BV10?
Ah, you know... A little B&O here, a little there
georgey007
Posts 74
The beovision is mkI build 227 sw (i think) is   04.66a
what i will do today is change ml cabel .
Will let u know if it helps
georgey007
Posts 74
Itried to change cabel ... No change !
are the puc entries delited when i set the tv to factory reset ?
regards
stefan
200 miles from Struer
Posts 2,920
stefan replied on Sun, Jul 28 2013 7:23 AM
Assuming you are using a 17XX Beo4 (didn`t read the whole thread..:) did you try to switch ZONE mode to ALL?
Stefan
Raeuber
Germany
Posts 2,542
Raeuber replied on Sun, Jul 28 2013 9:15 AM
georgey007:
No!
georgey007
Posts 74
Hi
I have a update!! Strange one !!
It seames that there are a older and a newer beo4 with nob! The newer one the one with 3d to select in add!
So the picturer mutes with the newer one, but not with the older one!!!
And it depends on the softwareupdate you have ofcourse Big Smile
Page 1 of 1 (31 items) | RSS
