Hi there
I have a beovision 10-46 in my living room on option 6 and a bs 9000 option 0 and a beovision 10-32 option 2 in the dinning room.
connection works fine but if i select a audio feed after warching tv the radio comes on but the tv is still showen. To switch of the picture i have first to switch off the tv an then switch it in radio on again.
any sugestions ?
regards
Why the option 6 in the livingroom tv together wth the 9000?
Why not option 2? - and option 6 for the 10-32 (I suppose they are close together and might both be reached with the Beo4 otherweise)?
Millemissen:Why the option 6 in the livingroom tv together wth the 9000? Why not option 2? - and option 6 for the 10-32 (I suppose they are close together and might both be reached with the Beo4 otherweise)? MM
This sounds like the reverse of my BV11 problem.
Sometimes when I switch from radio to TV the radio still picture (even if previously picture muted) comes on with the TV channel sound. I have to turn the TV off and wait a couple of minutes and then start again. In my case I think it's some sort of software issue combined with a locking-up of the internal tuner module.
My problem only happens when the audio is coming first from the internal TV 'Freeview' tuner.... my Beocenter etc Is all now in a separate room and not connected to the BV11 which will not work with Masterlink.
Graham
"That's correct, dear Millemissen. But if I understood it right, BS 9000 and BV 10-32 are located together in ONE room (dinning room). In this case the option settings are correct."
Dear Raueber,
well, I did understand that the audio system 'is located' with the BV10-46 - most people would do so! - and that the 10-32 is a link-tv
Untill it is clear what Georgy wants, we don't come any further.
Greetings Millemissen
Millemissen: Untill it is clear what Georgy wants, we don't come any further.
Hi
wow i must say a lot response :)
ok it seams that i have to lay out my whole setup.
In the dinnig room ( kitchen )
one beosound 9000 in option 0 as audio master
one beovision 10-32 as videomaster option 2 with beolab 4000 conectedn
as an extra listen zone beolink aktiv with pair of beolab 8000 in option 4
one beo4 as remote for this room
in the living room one beovision 10-46 with 1 beolab 1 2 beolab 6000 and 2 beolab4 in option 6
Bedroom one beovision 10-40 with beolab 1 in option 6
bathroom one beolink passiv in option 6
all with beo4 and masterlinkgateway
the audio master is playing well everywhere even in the livingroom
only thing is that the picture on the tv stays on when i switch to audio and istnt switching the display to black and after a while off
the 2 other beovision 10 are behaving as they should
All connected via ml of course
I would start with leaving the 10-46 not powered for a few minutes. If that doesn't work, a reset to default and put it back in option 6.
Long shot but worth a try.
"wow i must say a lot response :)"
Hmmm
i unpluged everything multible times ! But reset how do i do that ?
Yes i relocated and the whole wirering was done from skatch.
Millemissen:Very nice setup - indeed!
Thank u
The ml cabel i will change!
how do i get into the hidden menue
Regards
georgey007:The ml cabel i will change! how do i get into the hidden menue Regards
delteted
Wow, so much going on here - while I took a leave and watched some tele
I would start checking the junction box/es as Martin says.
N.B. Were changes made to the MLGW when relocated?
Did it work with the 10-46 before relocating?
Off topic: Raeuber - how shall I understand your 'off topic comment"?
Greetings MM
Millemissen: Off topic: Raeuber - how shall I understand your 'off topic comment"? Greetings MM
Hi Raeuber,
I know this a 'matter of controverse discussion' for you.
With the NL/ML Converter (and it needed the delay box) you can do exactly the same...
...and enjoy the possibilities of the new engine in the BV11/V1/BSys4 and forthcoming products.
Best of two worlds, I would say
But we shouldn't hijack this post - I am still curious to hear more from Georgy.
Greetings Millemaissen
What software is being run and what MK is your BV10?
Ah, you know... A little B&O here, a little there
The beovision is mkI build 227 sw (i think) is 04.66a
what i will do today is change ml cabel .
Will let u know if it helps
Itried to change cabel ... No change !
are the puc entries delited when i set the tv to factory reset ?
Assuming you are using a 17XX Beo4 (didn`t read the whole thread..:) did you try to switch ZONE mode to ALL?
Stefan
georgey007: are the puc entries delited when i set the tv to factory reset ?
