I use this one on my old Avant:
http://www.amazon.co.uk/SCART-Converter-Adapter-quality-converter/dp/B007WRPJX2/ref=sr_1_1?ie=UTF8&qid=1375256463&sr=8-1&keywords=Hdmi+to+scart
Easy to set up - not the best picture, but it won't get better.
A compromise, but allows me to use the ATV in the linkroom.
Isn't there a DVI-input on the BV7 32"?
Too long to list....
Yes there is, but is my understanding on the DVI connection correct it only allows pictures not sound and I would have to install an Optical to Analogue converter for sound from the Apple TV.
Or would this route give me a better picture and sound quality ?
For sure a better Picture AND digital Sound
Sound improvement:depends on your Speaker set-up, - if you use TVs Speakers only, Sound Quality is not an issue - if you have a 5.1 set-up, via Scart this it is not possible to feed 5.1.
Ralf
HDMI / DVI = digital Signal with Resolution made for your tv (720p, 1080i etc.)
Scart = Lower Resolution, TV has to do upscaling...
So just to confirm, the DVI takes sound as well as picture? So all that is needed is a DVI -> Scart cable?
x:________________________
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, 2014 Audi S5 with B&O sound, and ambio
What about this?
http://www.hdfury.com/no-hdmi-no-problem/
interesting thread on Apple Community https://discussions.apple.com/thread/2611942?start=0&tstart=0 about the HD Fury
All connected and working now and I must say I am rather impressed with the picture and sound quality when you take into consideration the the cabling and splitters involved.
What I like about doing such things and posting on this forum is what you learn, how boring if life was just all plug and go.
Note: the BV must be HD ready - otherweise this wouldn't work 'out of the box'.
I suppose a BC7-32 MK3 is!
Millemissen:Note: the BV must be HD ready - otherweise this wouldn't work 'out of the box'.
Mark: All connected and working now and I must say I am rather impressed with the picture and sound quality when you take into consideration the the cabling and splitters involved. What I like about doing such things and posting on this forum is what you learn, how boring if life was just all plug and go.
Hi Mark,
Can you please explain how it is connected? I get the DVI to HDMi plug, but I'm not sure on the other one (do you have a link to where I could find one?).
Thanks very much
Oh, and the best way to clean is with either a microfiber cloth or a spectacles cleaning cloth. No water or solvents are necessary, just a little bit of elbow grease
jldmelb:Oh, and the best way to clean is with either a microfiber cloth or a spectacles cleaning cloth. No water or solvents are necessary, just a little bit of elbow grease
BeoHut: jldmelb: Oh, and the best way to clean is with either a microfiber cloth or a spectacles cleaning cloth. No water or solvents are necessary, just a little bit of elbow grease ??? What do you mean by this Jonathan in relation to this topic? Clean old age equipment? Probably wrong post here ;-)
If you read the original question, the OP asks for the best way to clean fingerprints off the glass screen...
Helps a lot! Thanks Mark
Beofan53:"Also what is the best product you have found to clean the screen glass, 4 year old finger prints are a cleaners nightmare"
